[fdo-users] Where can I find the PostGIS 8.2.5 binaries ?
Traian Stanev
traian.stanev at autodesk.com
Wed Aug 5 10:19:27 EDT 2009
OK, I misunderstood, I thought you were trying to connect to PostGIS using the OGR provider, while in fact you are using the PostGIS provider. I don't know enough about the PostGIS provider in order to help with that. I assume that if it does not load the provider DLL, the PostGIS provider DLL is missing a dependent DLL. You can try running the dependency tool (depends.exe) on the provider DLL to see if any dependency is missing.
Traian
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-
> bounces at lists.osgeo.org] On Behalf Of rgc03 at eprinsa.es
> Sent: Wednesday, August 05, 2009 2:35 AM
> To: FDO Users Mail List
> Subject: RE: [fdo-users] Where can I find the PostGIS 8.2.5 binaries ?
> Hi Traian. Sorry for my english.
> I mean that in my AutoCad Map 3D 2009, in "File/Connect to data" I
> have several options to choose (ArcSDE connection, SHP connection, SDF
> connection, Oracle connection, OGR Connection, PostGIS connection, etc).
> The OGR Connection it´sok, but I can´t get the PostGIS Connection works
> properly. When I select "PostGis conenction" appears "Data connection
> provider can´t be loaded" or somenthing similar (sorry, my Autocad it´s in
> spanish).
> Thanks
> RGC
> De: Traian Stanev <traian.stanev at autodesk.com>
> Para: "fdo-users at lists.osgeo.org" <fdo-users at lists.osgeo.org>
> Fecha: 04/08/2009 18:19
> Asunto: RE: [fdo-users] Where can I find the PostGIS 8.2.5 binaries ?
> Enviado fdo-users-bounces at lists.osgeo.org
> por:
> No idea why, those two builds have been specifically tested to work with
> PostGIS on FDO 3.3 (which should be what Map 2009 uses).
> Also, I don’t fully understand what you mean by “OGR connection runs but the
> PostGIS connection doesn’t”.
> Traian
> From: fdo-users-bounces at lists.osgeo.org [ mailto:fdo-users-
> bounces at lists.osgeo.org] On Behalf Of RGC
> Sent: Tuesday, August 04, 2009 2:31 AM
> To: fdo-users at lists.osgeo.org
> Thank you Traian, but with the alternative provider DLL you posted it
> still not working properly. In the FDO menu, the OGR Conections runs, but
> the PostGIS conection doesn't.
> Any idea?
> Thanks in advance
> RGC
> | De: |
> |"Traian Stanev (via Nabble)" <[hidden email]>
> | Para: |
> |RGC <[hidden email]>
> | Fecha: |
> |03/08/2009 17:44
> | Asunto: |
> You can also try either of the following alternative provider DLL builds to
> see if it makes a difference:
> http://13-9.com/OGRProvider-3.3.0.zip
> http://13-9.com/OGRProvider-3.3-utf8.zip
> Traian
> > From: [hidden email] [mailto:fdo-users- [hidden email]] On Behalf Of
> > RGC
> > Sent: Monday, August 03, 2009 2:06 AM
> > To: [hidden email]
> > Subject: [fdo-users] Where can I find the PostGIS 8.2.5 binaries ?
> > Hi all.
> > I can´t configure the OGR driver provider to my FDO conections in
> > Autocad
> > Map 2009.
> > Autocad Map 2009 needs the PostGIS 8.2.5 binaries, but in the URL
> > http://n2.nabble.com/FDO-Users-f2048584.html, I have tried several
> > links
> in
> > this download page, but it seems that none is working.
> > Anybody can tell me where can I find this binaries or send to me?
> > Thanks
> > Rafa
> > PD: I´ve tried with others versions of the PostGIS binaries but the
> > FDO connection not work properly.
> > View this message in context:
> > http://n2.nabble.com/Where-can-I-find-the-
> > PostGIS-8.2.5-binaries---tp3376079p3376079.html
> > Sent from the FDO Users mailing list archive at Nabble.com.
> > fdo-users mailing list
> > [hidden email]
> > http://lists.osgeo.org/mailman/listinfo/fdo-users
> [hidden email]
> View message @
> http://n2.nabble.com/Where-can-I-find-the-PostGIS-8.2.5-binaries---
> tp3376079p3378551.html
> To unsubscribe from Where can I find the PostGIS 8.2.5 binaries ?, click
> here.
> View this message in context: RE: [fdo-users] Where can I find the PostGIS
> 8.2.5 binaries ?
More information about the fdo-users
