[fdo-users] metada access (shp.xml)
Ricostas ricolastas at gmail.com
Wed Aug 5 10:20:13 EDT 2009
Hi Dan,
Thank you for your answer.
In fact i need to collect some information contain in a xml file.
Each of my shpfile has a .xlm associate file. This xml document contains the
metadata of the shp file.
For exemple, i need to collect the chain of character between the two tag:
<ftname>article55_sru02</ftname>
May be it's better to use some method of the  FdoXmlReader   class...
But i wan to know if it's possible to do that with a query command like
CommandType_Select
I hope that my question is comprehensible :)
Regards,
Eric
Dan Stoica wrote:
> Hi,
> Here is an example (unmanaged):
>         FdoPtr<FdoIConnection> connection = ...;
>         connection->SetConnectionString (L"DefaultFileLocation="
> ONTARIO_LOCATION);
>         FdoIoFileStreamP fileStream =
> FdoIoFileStream::Create(L"ShpSchemaConfig.xml", L"r");
>         connection->SetConfiguration(fileStream);
>         connection->Open();
> Is this what you need?
> Dan.
> From: fdo-users-bounces at lists.osgeo.org
> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Eric Dureault
> Sent: Tuesday, August 04, 2009 10:21 AM
> To: fdo-users at lists.osgeo.org
> Subject: [fdo-users] metada access (shp.xml)
> Hello,
> I am currently working on a project of administration of geographic data.
> For now, I'm just working on data in the format shape (shp).
> I've begun to work with FDO last week so i have not a great experience...
> I create a connection:
> fdoconnectionmgr = FeatureAccessManager.GetConnectionManager()
> iconnection = fdoconnectionmgr.CreateConnection(OSGeo.SHP.3.4)
> and open it with this connectionstring:
> iconnection.ConnectionString = "DefaultFileLocation = C:\....\road.shp"
> iconnection.Open()
> The connectoin state is correctly show as "open"
> Now I need to access to the metada contain in the .xml associed file and i
> don't know how to do this...
> Is it possible to do this with : CommandType.CommandType_Select  or i need
> to use something else?
> Have you got an exemple for this type of query commands?
> Appreciate your cooperation in advance
> Regards,
> Eric
> fdo-users mailing list
> http://lists.osgeo.org/mailman/listinfo/fdo-users
View this message in context: http://n2.nabble.com/metada-access-%28shp.xml%29-tp3384807p3392170.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users mailing list
