[fdo-users] FDOPostGIS 3.4L Check In of New generated PointFeature
causes ErrorMessage
Hermann Karl
Karl.Hermann at dornbirn.at
Tue Aug 11 03:53:08 EDT 2009
Dear List,
I tested FDO-Insert on the data from the previous message (gid PRIMARY
KEY SERIAL) with FDO Toolbox http://fdotoolbox.googlecode.com from
Jackie Ng and the Providers FDOPostGIS 3.4L from geomapgis and
FDOPostGIS 3.4.0 from OSGEO.
!!!!! I did not have any problems to insert a new feature. !!!!!
!!!!! It seems that there is a serious problem of AutoCAD Map 3d 2010
with the FDOPostGIS Provider 3.4 !!!!!.
I have tested the proposed "workaround" from David Anderson
http://lists.osgeo.org/pipermail/fdo-users/attachments/20090716/a22481f5
/postgistable.obj with FDO Toolbox and it works too.
-- create sequence --
CREATE SEQUENCE public.blocktest5_gid_seq
INCREMENT 1
MINVALUE 1
MAXVALUE 9223372036854775807
START 1
CACHE 1;
ALTER TABLE public.blocktest5_gid_seq OWNER TO postgres;
-- create function --
CREATE OR REPLACE FUNCTION public.autoinc_blocktest5_gid_trig()
RETURNS trigger AS
$BODY$
declare
begin
select nextval('public.blocktest5_gid_seq') into new.gid;
return new;
end;
$BODY$ LANGUAGE plpgsql VOLATILE;
-- COST 100;
ALTER FUNCTION public.autoinc_blocktest5_gid_trig() OWNER TO postgres;
-- create table --
CREATE TABLE "blocktest5" ("gid" int PRIMARY KEY DEFAULT 1,
"blockname" varchar(255),
"layer" varchar(255),
"rotation" numeric,
"s" varchar(255),
"u" varchar(255));
SELECT AddGeometryColumn('','blocktest5','the_geom','-1','POINT',2);
-- create trigger --
CREATE TRIGGER autoinc_blocktest5_gid
BEFORE INSERT
ON public.blocktest5
FOR EACH ROW
EXECUTE PROCEDURE public.autoinc_blocktest5_gid_trig();
-- insert points --
INSERT INTO "blocktest5"
("blockname","layer","rotation","s","u",the_geom) VALUES
('GN1','GN','0.000000000000000','789',NULL,'0101000000FDA08A2C9FB3E3C0B9
770762A8FA0E41');
('GN2','GN','0.000000000000000','2345','6','0101000000E54B15C275B3E3C053
379F6D81F90E41');
Any comments from autodesk ?
Karl
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20090811/e0255374/attachment.html
More information about the fdo-users
