[fdo-users] Using MS Access Databases by aid of FDO (64bit appl.)
Michael Rembe rembe at wt-geoingenieure.de
Tue Aug 25 02:49:34 EDT 2009
I'm using AutoCAD Map 3D 2010 on a 64bit windows vista. By aid of the
fdo-provider v. 3.4.0 I access to my data. Because of the microsoft jet
engine (32bit) there isn't a way to use MS Access Databases (*.mdb
files)from a 64bit application (neither ODBS nor direct to the mdb-file). I
think you know it.
will be there a new release on 64bit supporting Access-Databases? When will
you relase a new version?
Thank you! Best regards, Michael
View this message in context: http://n2.nabble.com/Using-MS-Access-Databases-by-aid-of-FDO-64bit-appl-tp3508106p3508106.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users mailing list
