[fdo-users] ODBC MS SQL Server error feature on check in after
editing
kalmy
kalman.albert at promax.ro
Mon Dec 14 06:54:29 EST 2009
No, I use Express edition of SQL Server and I think the Profiler is not
availabel. The screenshot is from Management Studio Express 2008, I use
2000 MSDE and 2008 Express database structure.
but ... I think I discover the issue, I change the type of field from
numeric(18,3) with real for X,Y columns and works but it's strange and I
don't why ? Is this a limitation of ODBC provider ?
Also I noticed the FDO version of odbc is 3.4.0.5301 in map folder and from
toolbox is 3.4.0.56 .The newer is better ?
Kalmy
Jackie Ng wrote:
> From your screenshot, I assume you're not using the express edition of SQL
> Server.
> In that case, there should be a SQL Server Profiler installed. Run it and
> configure it to watch for T-SQL statements. Run your FDO insert command
> again and see what SQL is being fed to SQL Server.
> - Jackie
> kalmy wrote:
>> Can you tell me where/how can I turn on the tracing ?
>> Kalmy
View this message in context: http://n2.nabble.com/ODBC-MS-SQL-Server-error-feature-on-check-in-after-editing-tp4108036p4163685.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users
