[fdo-users] Get Property datatype
Jackie Ng
jumpinjackie at gmail.com
Thu Dec 17 05:51:43 EST 2009
PropertyType tells you what you can safely cast that PropertyDefinition into
PropertyType_AssociationProperty means cast it to a
AssociationPropertyDefinition
PropertyType_GeometricProperty means cast it to a
GeometricPropertyDefinition
PropertyType_ObjectProperty means cast it to a ObjectPropertyDefinition
PropertyType_RasterProperty means cast it to a RasterPropertyDefinition
PropertyType_DataProperty means cast it to a DataPropertyDefinition
Thus you want to check if the property is a data property, then you can
safetly cast to a DataPropertyDefinition and interrogate its DataType
property to determine the data type.
- Jackie
Matteo wrote:
> Hi,
> I have a question about the featureclass properties. How I can get the
> datatype of a property? When I get a property of a featureclass
> (objSchema.Item(0).Classes.Item(0).Properties.item(0)) I found only the
> PropertyType method. This method non return the datatype but the type of
> property (PropertyType_DataType). I need a method that return the exactly
> data type (ex DataType_Int16)
> Another question:
> how I can get type geometry type of a SHP file (Point, Line, Surface)?
> Thanks
> Matteo
View this message in context: http://n2.nabble.com/Get-Property-datatype-tp4180458p4180623.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users
