[fdo-users] Insert object on a existing SHP file
Haris Kurtagic
haris at sl-king.com
Sun Dec 20 15:27:18 EST 2009
Jason, you are correct there.
Here is description how to setup :
http://www.sl-king.com/fdooracle/KingOracleSetup.html section Oracle
Sequence "_FDOSEQ"
Haris
On Sun, Dec 20, 2009 at 9:16 PM, Jason Birch <jason at jasonbirch.com> wrote:
> Have you considered setting the oracle table up with a trigger that
> inserts the next value from a sequence?
> I think king.oracle may have some special naming-convention-based
> handling around sequences that the trigger may not be required... I
> haven't used it for a while though so not sure.
> Jason
> On 2009-12-20, Matteo <matteo.conte1979 at libero.it> wrote:
> > Hi all,
> > I have a class in OracleXE with FeatId as IdentityProperty
> (autogenerate).
> > The class isn't void. When I try to insert new feature in the class I get
> an
> > error because I haven't compile the FeatId column. How I can retrieve the
> > max value of FeatId column using VS.NET? I use King provider
> > Regards,
> > Matteo
> > View this message in context:
> http://n2.nabble.com/Insert-object-on-a-existing-SHP-file-tp4194807p4194807.html
> > Sent from the FDO Users mailing list archive at Nabble.com.
> > fdo-users mailing list
> > fdo-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/fdo-users
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20091220/7ae527a4/attachment.html
More information about the fdo-users
