[fdo-users] ISelectAggregates: how use it to COUNT?
Dan Stoica
dan.stoica at autodesk.com
Tue Dec 22 16:03:28 EST 2009
Hi Matteo,
In general you can check the unit tests (basically any provider) for virtually any snippet you need.
For Count(), I've copied this from the SHP unit tests:
FdoPtr<FdoISelectAggregates> select = (FdoISelectAggregates*)mConnection->CreateCommand (FdoCommandType_SelectAggregates);
select->SetFeatureClassName (className);
select->SetDistinct(false);
FdoPtr<FdoIdentifierCollection> selectedIds = select->GetPropertyNames();
selectedIds->Clear();
selectedIds->Add(FdoPtr<FdoComputedIdentifier>(FdoComputedIdentifier::Create(L"Total", FdoPtr<FdoExpression>(FdoExpression::Parse(L"Count(\"Date\")")))));
FdoPtr<FdoIDataReader> datareader = select->Execute ();
long count = 0;
while (datareader->ReadNext ())
FdoInt64 total = datareader->GetInt64(L"Total");
CPPUNIT_ASSERT_MESSAGE("Count wrong", 4L == total);
count++;
Dan.
-----Original Message-----
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Matteo
Sent: Tuesday, December 22, 2009 3:50 PM
To: fdo-users at lists.osgeo.org
Subject: [fdo-users] ISelectAggregates: how use it to COUNT?
Hi all,
I need to know how I can use the ISelectAggregates command? (Ex. how I can
do to get the count the object? or to get the MAX of a property?
Regards
Matteo
View this message in context: http://n2.nabble.com/ISelectAggregates-how-use-it-to-COUNT-tp4205687p4205687.html
Sent from the FDO Users mailing list archive at Nabble.com.
fdo-users mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users
