[fdo-users] FDO OGR Provider for PostGreSQL 8.3 + PostGis
Paulo Azevedo
psergio at mediaprimer.pt
Thu Feb 5 05:50:06 EST 2009
Hello Traian.
Thanks for the fast reply.
This solution work for me.
Many thanks.
Paulo
Traian Stanev wrote:
> This is probably because the default GDAL/OGR dll available with FDO
> does not include GDAL support. You can try using this provider DLL:
> http://13-9.com/OGRProvider-3.3.0.zip
> It is static-linked to a GDAL that's compiled with Postgres support.
> Note that it requires that the *libpq.dll* (the PostgresSQL support
> dll) be somewhere in the system path.
> Traian
> *From:* fdo-users-bounces at lists.osgeo.org
> [mailto:fdo-users-bounces at lists.osgeo.org] *On Behalf Of *Paulo Azevedo
> *Sent:* Wednesday, February 04, 2009 12:17 PM
> *To:* mapguide-users at lists.osgeo.org; portugal at lists.osgeo.org;
> fdo-users at lists.osgeo.org
> *Subject:* [fdo-users] FDO OGR Provider for PostGreSQL 8.3 + PostGis
> Hi all,
> I'm trying to connect Mapguide OS 2.0.2 with a PostGreSQL 8.3 +
> PostGis database via FDO OGR Provider 3.3.0.
> I have downloaded the provider dll from OSGeo Website, and put them in
> the MapGuideOpenSource2.0\Server\Bin\FDO folder and updated the
> providers.xml file.
> After that i try to create a DataConnection in MapGuide Maestro,
> selected the OSGeo FDO Provider for OGR then i fill the DataSource
> field whith PG:host=myHost dbname=myDBName user=myUser
> password=myPassword port=5432 (this are fake names) and the Readonly
> field with TRUE, but when i press the Test connection button occurs
> the following error:
> *The remote server returned an error: (559) MgFdoException.:
> An exception occurred in FDO component.
> Connect failed:
> Exception occurred in method MgFdoConnectionManager.Open at line 858
> in file
> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\common\manager\FdoConnectionManager.cpp*
> Did i forget some step or DLL?
> Thanks for your time!
> Best regards,
> Paulo
> fdo-users mailing list
> http://lists.osgeo.org/mailman/listinfo/fdo-users
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20090205/42bf2df0/attachment-0001.html
More information about the fdo-users
