[fdo-users] Trying to Deploy FDO to Web
Greg Boone
greg.boone at autodesk.com
Tue Feb 17 11:35:03 EST 2009
Have you run depends.exe to try and determine which module cannot be found?
-----Original Message-----
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of surrounded
Sent: Tuesday, February 17, 2009 11:06 AM
To: fdo-users at lists.osgeo.org
Subject: [fdo-users] Trying to Deploy FDO to Web
Hello,
I'm using FDO within VS 2008 project (web service) and works fine when run
as localhost on my PC.
I've moved the web service to a production server, copied the FDO bin, lib,
and inc folders to the production server, and set the environment PATH
variable on the server to point to the FDO folders.
When I run the application I get the following error:
System.IO.FileNotFoundException: The specified module could not be found.
(Exception from HRESULT: 0x8007007E)
ANY IDEAS ON WHAT IS CAUSING THIS? HOW IS FDO SET UP TO RUN ON WEB SERVER?
Thanks.....
View this message in context: http://n2.nabble.com/Trying-to-Deploy-FDO-to-Web-tp2341612p2341612.html
Sent from the FDO Users mailing list archive at Nabble.com.
fdo-users mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users
