[fdo-users] Trying to Deploy FDO to Web
surrounded
Rob.Sosnowski at itd.idaho.gov
Tue Feb 17 11:46:17 EST 2009
Using DependencyWalker, I see that for OSGeo.FDO.dll and
OSGeo.FDO.Common.dll, DWMAPI.DLL cannot be found.
ANYONE RUN INTO THIS - RECOMMENDATION?
surrounded wrote:
> Hi Greg,
> No, so if I download Depends.exe, how would I use it to determine the
> missing module??
> From: Greg Boone (via Nabble)
> [mailto:ml-user+67529-964960874 at n2.nabble.com]
> Sent: Tuesday, February 17, 2009 9:36 AM
> To: Rob Sosnowski
> Subject: RE: [fdo-users] Trying to Deploy FDO to Web
> Have you run depends.exe to try and determine which module cannot be
> found?
> -----Original Message-----
> From: fdo-users-bounces at ...
> <http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2341773&i=0>
> [mailto:fdo-users-bounces at ...
> <http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2341773&i=1> ]
> On Behalf Of surrounded
> Sent: Tuesday, February 17, 2009 11:06 AM
> To: fdo-users at ...
> <http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2341773&i=2>
> Subject: [fdo-users] Trying to Deploy FDO to Web
> Hello,
> I'm using FDO within VS 2008 project (web service) and works fine when
> run
> as localhost on my PC.
> I've moved the web service to a production server, copied the FDO bin,
> lib,
> and inc folders to the production server, and set the environment PATH
> variable on the server to point to the FDO folders.
> When I run the application I get the following error:
> System.IO.FileNotFoundException: The specified module could not be
> found.
> (Exception from HRESULT: 0x8007007E)
> ANY IDEAS ON WHAT IS CAUSING THIS? HOW IS FDO SET UP TO RUN ON WEB
> SERVER?
> Thanks.....
> http://n2.nabble.com/Trying-to-Deploy-FDO-to-Web-tp2341612p2341612.html
> Sent from the FDO Users mailing list archive at Nabble.com.
> fdo-users mailing list
> fdo-users at ...
> <http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2341773&i=3>
> http://lists.osgeo.org/mailman/listinfo/fdo-users
> fdo-users at ...
> <http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2341773&i=4>
> ________________________________
> This email is a reply to your post @
> http://n2.nabble.com/Trying-to-Deploy-FDO-to-Web-tp2341612p2341773.html
> You can reply by email or by visting the link above.
View this message in context: http://n2.nabble.com/Trying-to-Deploy-FDO-to-Web-tp2341612p2341870.html
More information about the fdo-users
