[fdo-users] FDO 3.4.0 Beta 1 - SQL 2008 - empty schema
miansi
AndreiSinelnikov at SierraSystems.com
Tue Feb 17 14:42:24 EST 2009
SHEMABINDING and ANSI_NULLS ON didn't make a difference.
I believe it is JOIN which is causing this problem.
http://n2.nabble.com/Joins-using-FDO-SQL-Server-Spatial-td2311594.html
Still though... Cannot believe there is no setting, which will override PK
assignment.
Orest Halustchak wrote:
> SQL Server has a number of requirements for setting up this view, it has
> to be a deterministic view and there are a number of settings that have to
> be defined such as SET ANSI_NULLS ON. Also you have to use SCHEMABINDING.
> I was able to set up a view this way and use Map to view the data and
> create new features. In MG, I was able to draw the layer and select the
> feature. My view was a simple view, though.
> Could you post your view definition?
> Thanks,
> Orest.
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org
> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of miansi
> Sent: Monday, February 16, 2009 4:07 PM
> To: fdo-users at lists.osgeo.org
> Subject: RE: [fdo-users] FDO 3.4.0 Beta 1 - SQL 2008 - empty schema
> I moved post to FDO forum.
> And yes. I tried indexed views - no luck.
> I was wondering too if it is possible to specify in the layer XML or Map
> XML
> that particular column is primary key.
> Does anyone aware of such method? Can it be done?
> Thank you
> Jason Birch wrote:
>> MapGuide does not allow selection from tables/views without primary keys.
>> Basically, without a primary key there is no way to ensure that you're
>> selecting the correct object.
>> Have you tried setting up an indexed view? I don't have any experience
>> with this, but...
>> http://msdn.microsoft.com/en-us/library/dd171921.aspx
>> I wonder if there is a way to create a configuratin file for your data
>> source that specifies its schema (including a manual override of the
>> primary key column). The FDO mailing list may be able to help...
>> Jason
>> ________________________________
>> From: miansi
>> Sent: Mon 2009-02-16 10:23 AM
>> To: mapguide-users at lists.osgeo.org
>> Subject: RE: [mapguide-users] FDO 3.4.0 Beta 1 - SQL 2008 - empty schema
>> On the map and inside my application I need to present information joined
>> from both tables. For that I created SQL view and used it.
>> Everything is OK, but I cannot select anything on this layer. I see
>> features
>> on the map, I see mouse pointer changing its shape from ][ to arrow, but
>> neither clicking on feature nor selecting area, which includes multiple
>> features do select features.
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://n2.nabble.com/FDO-3.4.0-Beta-1---SQL-2008---empty-schema-tp2322472p2337221.html
> Sent from the FDO Users mailing list archive at Nabble.com.
> fdo-users mailing list
> http://lists.osgeo.org/mailman/listinfo/fdo-users
View this message in context: http://n2.nabble.com/FDO-3.4.0-Beta-1---SQL-2008---empty-schema-tp2322472p2342843.html
More information about the fdo-users
