[fdo-users] Trying to Deploy FDO to Web
surrounded
Rob.Sosnowski at itd.idaho.gov
Tue Feb 17 15:36:37 EST 2009
OK, I finally got this to work on production web server, though to be honest
with those reading this I have no idea how. I went into properties on IIS
for the virtual directory, opened it, checked settings, got back out and it
started to work. Hope this is an isolated incident.....
surrounded wrote:
> Greg,
> Using Windows XP, VS 2008, .Net 3.5, created web service using FDO. Web
> service works wonderful from VS 2008 debug, localhost, and by access
> from Silverlight web application.
> I've now tried to move the web service to a production server (Windows
> Server 2003) by: copying over the webservice published code, copying
> over the FDO bin, inc, and lib folders, changing the PATH environment
> variable on the server to point to the FDO bin, inc, lib folders.
> Nonetheless, I get the following error when I run the web service on the
> server:
> System.IO.FileNotFoundException: The specified module could not be
> found. (Exception from HRESULT: 0x8007007E)
> An unhandled exception was generated during the execution of the current
> web request. Information regarding the origin and location of the
> exception can be identified using the exception stack trace below.
> I've tried FDO versions 3.3.1, 3.3.2, 3.3.4; all have resulting in same
> error. DependencyWalker just states that I'm missing DWMAPI.dll, which
> you pointed out should not matter.
> WHAT AM I MISSING....
> From: Greg Boone (via Nabble)
> [mailto:ml-user+67529-964960874 at n2.nabble.com]
> Sent: Tuesday, February 17, 2009 10:04 AM
> To: Rob Sosnowski
> Subject: RE: [fdo-users] Trying to Deploy FDO to Web
> That DLL should be delay loaded and should not affect FDO from running.
> Have you looked at the contents of providers.xml located in the FDO bin
> directory? Are the paths to the provider files relative or absolute?
> Greg
> -----Original Message-----
> From: fdo-users-bounces at ...
> <http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2341971&i=0>
> [mailto:fdo-users-bounces at ...
> <http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2341971&i=1> ]
> On Behalf Of surrounded
> Sent: Tuesday, February 17, 2009 11:46 AM
> To: fdo-users at ...
> <http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2341971&i=2>
> Using DependencyWalker, I see that for OSGeo.FDO.dll and
> OSGeo.FDO.Common.dll, DWMAPI.DLL cannot be found.
> ANYONE RUN INTO THIS - RECOMMENDATION?
> surrounded wrote:
>> Hi Greg,
>> No, so if I download Depends.exe, how would I use it to determine the
>> missing module??
>> [mailto:ml-user+67529-964960874 at ...
> <http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2341971&i=3> ]
>> Sent: Tuesday, February 17, 2009 9:36 AM
>> To: Rob Sosnowski
>> Have you run depends.exe to try and determine which module cannot be
>> found?
>> <http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2341773&i=0>
>> <http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2341773&i=1> ]
>> Sent: Tuesday, February 17, 2009 11:06 AM
>> <http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2341773&i=2>
>> Subject: [fdo-users] Trying to Deploy FDO to Web
>> Hello,
>> I'm using FDO within VS 2008 project (web service) and works fine when
>> run
>> as localhost on my PC.
>> I've moved the web service to a production server, copied the FDO bin,
>> lib,
>> and inc folders to the production server, and set the environment PATH
>> variable on the server to point to the FDO folders.
>> When I run the application I get the following error:
>> found.
>> ANY IDEAS ON WHAT IS CAUSING THIS? HOW IS FDO SET UP TO RUN ON WEB
>> SERVER?
>> Thanks.....
>> View this message in context:
> http://n2.nabble.com/Trying-to-Deploy-FDO-to-Web-tp2341612p2341612.html
>> Sent from the FDO Users mailing list archive at Nabble.com.
>> fdo-users mailing list
>> fdo-users at ...
>> <http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2341773&i=3>
>> http://lists.osgeo.org/mailman/listinfo/fdo-users
>> fdo-users at ...
>> <http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2341773&i=4>
>> This email is a reply to your post @
> http://n2.nabble.com/Trying-to-Deploy-FDO-to-Web-tp2341612p2341773.html
>> You can reply by email or by visting the link above.
> http://n2.nabble.com/Trying-to-Deploy-FDO-to-Web-tp2341612p2341870.html
> fdo-users at ...
> <http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2341971&i=4>
> fdo-users at ...
> <http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2341971&i=5>
> http://n2.nabble.com/Trying-to-Deploy-FDO-to-Web-tp2341612p2341971.html
View this message in context: http://n2.nabble.com/Trying-to-Deploy-FDO-to-Web-tp2341612p2343130.html
More information about the fdo-users
