[fdo-users] getting data using SHP provider
Dan Stoica
dan.stoica at autodesk.com
Fri Feb 20 10:14:08 EST 2009
Try "Signs" instead of "signs".
-----Original Message-----
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of VJ
Sent: Friday, February 20, 2009 10:05 AM
To: fdo-users at lists.osgeo.org
Subject: RE: [fdo-users] getting data using SHP provider
Dan Stoica wrote:
> Assuming signs.shp exists, how your connection string looks like?
The connectionstring reads:
DefaultFileLocation=D:\gis_db_interface\sample_data\;TemporaryFileLocation=D:\temp;
It was created with the commands
ConnDict->SetProperty(L"DefaultFileLocation",
L"D:\\gis_db_interface\\sample_data\\");
ConnDict->SetProperty(L"TemporaryFileLocation", L"D:\\temp");
The directory holds Signs.shp, Signs.dbf, Signs.idx, Signs.prj, Signs.sbn,
Signs.sbx, Signs.shx. The shapefile opens (and shows all attributes) in
udig. I also tried with another set of files, but with the same result.
View this message in context: http://n2.nabble.com/getting-data-using-SHP-provider-tp2358940p2359351.html
Sent from the FDO Users mailing list archive at Nabble.com.
fdo-users mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users
