[fdo-users] KingOra 3.4 RC1 Query
Orest Halustchak orest.halustchak at autodesk.com
Mon Feb 23 17:27:24 EST 2009
Hi Haris,
This is just to let you know that Greg is away this week, so won't be able to get back to you right away.
Orest.
-----Original Message-----
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Haris Kurtagic
Sent: Monday, February 23, 2009 3:34 AM
To: FDO Users Mail List
Subject: RE: [fdo-users] KingOra 3.4 RC1 Query
Yes, I have worked on 0.8.5 using different code base then the one in
repository ( 0.8.5 is using OCI instead of OCCI Oracle interface).
I haven't submit into FDO trunk yet, mainly because in trunk are changes
done to build on Linux which I don't have in 0.8.5.
I believe that work for Linux build has been done by Greg.
My question goes to Greg If I submit and then again apply changes for
Linux build or I try to check differences. Second option looks like more
work to me, because there would be lot of differences between versions.
So Greg, which way is less work ? :)
Haris
[mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: Monday, February 23, 2009 12:44 AM
To: fdo-users at lists.osgeo.org
Subject: Re: [fdo-users] KingOra 3.4 RC1 Query
Just looking at the svn logs, it seems that 0.85 has been developed
outside
of this svn repository. There does not seem to be any indications that
the
changes/enhancements in 0.85 were merged back into svn.
Haris would give you a better answer (of course).
- Jackie
Crispin_at_1Spatial wrote:
> Hi,
> We have a .net application (MapRelate) currently using FDO 3.3 and I
have
> today created a new project and updated the references to the 3.4 RC1
SDK
> files.  Basic compile and run-time look fine (on the surface) but
KingOra
> is not reading the Oracle schema I test against in the office.
> Is the KingOra in 3.4 a rebuild of 3.3 (KingOra v.74?) or is it based
on
> the new (v0.85?) version that has some known issues with some schema
> description/discovery?
>  Crispin
View this message in context:
http://n2.nabble.com/KingOra-3.4-RC1-Query-tp2368175p2369665.html
Sent from the FDO Users mailing list archive at Nabble.com.
fdo-users mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users mailing list
