[fdo-users] SQL 2008. View with JOINS. Not able to selectfeatures
on the layer.
Jason Birch
Jason.Birch at nanaimo.ca
Sat Feb 28 15:09:14 EST 2009
Brent,
Do you think that the capabilities reporting change for #469 is non-invasive enough that it could be implemented prior to 3.4 release?
If the provider already supports configuration, it looks to me like it would only require a couple lines in FdoRdbmsSqlServerConnectionCapabilities.h and FdoRdbmsSqlServerConnectionCapabilities.cpp. I don't know enough about C++ to know whether overriding these inherited properties in the sql server connection capabilities class would break anything though.
This question has come up quite a few times on the mailing lists now, and it would be nice to at least have a workaround for supporting SQL Server views.
Jason
Sent: Fri 2009-02-27 7:47 AM
To: FDO Users Mail List
Subject: RE: [fdo-users] SQL 2008. View with JOINS. Not able to selectfeatures on the layer.
One way to specify the identity properties is through a config document, which can be attached to the feature source. Unfortunately, the SQLServerSpatial advertises that it does not support config documents even though it does. I've logged a trac ticket (http://trac.osgeo.org/fdo/ticket/469) for this defect.
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/fdo-users/attachments/20090228/d8e71134/attachment.bin
More information about the fdo-users
