[fdo-users] [mapguide-users] Compile fdo-3.4.0 on debian lenny
crossroad
jesuchristopher at gmail.com
Thu Jan 15 19:41:52 EST 2009
now i have the following errors:
/opt/OpenSource/Thirdparty/apache/xml-xalan/c/src/xalanc/XalanDOM/XalanDOMString.cpp:
In member function ‘xalanc_1_7::XalanDOMString&
xalanc_1_7::XalanDOMString::assign(const xalanc_1_7::XalanDOMString&,
size_t, size_t)’:
/opt/OpenSource/Thirdparty/apache/xml-xalan/c/src/xalanc/XalanDOM/XalanDOMString.cpp:274:
error: ‘memmove’ was not declared in this scope
In static member function ‘static size_t
xalanc_1_7::XalanDOMString::length(const char*)’:
/opt/OpenSource/Thirdparty/apache/xml-xalan/c/src/xalanc/XalanDOM/XalanDOMString.cpp:808:
error: ‘strlen’ was not declared in this scope
In function ‘bool xalanc_1_7::doTranscodeFromLocalCodePage(const char*,
size_t, bool, xalanc_1_7::XalanDOMCharVectorType&, bool)’:
/opt/OpenSource/Thirdparty/apache/xml-xalan/c/src/xalanc/XalanDOM/XalanDOMString.cpp:1131:
error: ‘strncpy’ was not declared in this scope
make[1]: *** [../../obj/XalanDOMString.o] Error 1
make[1]: se sale del directorio
`/opt/OpenSource/Thirdparty/apache/xml-xalan/c/src/xalanc'
make: *** [all] Error 2
thank
Greg Boone wrote:
> Yes. Just define a valid value for FDOGDAL and the build should work.
> Typically, the FDOGDAL variable is pointed to
> .../fdo/trunk/Thirdparty/gdal but you can point it to whatever copy of the
> GDAL sdk you want to use.
> Greg
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org
> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Jason Birch
> Sent: Thursday, January 15, 2009 1:39 PM
> To: FDO Users Mail List
> Subject: [fdo-users] RE: [mapguide-users] Compile fdo-3.4.0 on debian
> lenny
> Sorry, I should have included this part of the original in my cross-post
> so FDO users would know what the heck I was talking about.
> make[2]: se sale del directorio
> `/opt/OpenSource/Thirdparty/openssl/test'
> making all in tools...
> make[1]: se ingresa al directorio
> `/opt/OpenSource/Thirdparty/openssl/tools'
> make[1]: No se hace nada para `all'.
> Building of the Thirdparty/GDAL libraries has been skipped. Environment
> variable FDOGDAL points to a previously installed version of GDAL at .
> This version of GDAL will be used to build the FDO WMS and GDAL
> providers.
> make[1]: se ingresa al directorio `/opt/OpenSource/Thirdparty'
> make[1]: *** No hay ninguna regla para construir el objetivo
> `apache/xml-xalan/c/lib/libxalan-c.so.17.0', necesario para `all-am'.
> Alto.
> make[1]: se sale del directorio `/opt/OpenSource/Thirdparty'
> make: *** [install-recursive] Error 1
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jason Birch
> Sent: January-15-09 10:36 AM
> To: MapGuide Users Mail List; FDO Users Mail List
> Subject: RE: [mapguide-users] Compile fdo-3.4.0 on debian lenny
> Your question is better asked on FDO-Users...
> I've seen this problem too; I believe that I had to fix something in the
> build script, or maybe define FDOGDAL to get it to work, but can't
> remember exactly what.
> Jason
> From: crossroad
> Subject: [mapguide-users] Compile fdo-3.4.0 on debian lenny
> I have successfully built mapguideaptinstaller-2.0.0.2.tar.gz
> But I cannot compile the FDO Thirdparty on debian lenny
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
> fdo-users mailing list
> fdo-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-users
View this message in context: http://n2.nabble.com/RE%3A--mapguide-users--Compile-fdo-3.4.0-on-debian-lenny-tp2164124p2165847.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users
