[fdo-users] MapGuide MapGuide 2.1.0 (Beta) with PostGIS provider
Mike Toews
mwtoews at sfu.ca
Wed Jul 1 21:48:03 EDT 2009
The error message "Cannot establish connection" tells me that you might
need to revise the connection settings (details at
http://trac.osgeo.org/fdo/wiki/FdoPostGISNotes ). If you are not using a
superuser account (i.e., postgres), make sure you are using an account
that has connect/view permissions on essential tables
(public.geometry_columns, etc.) and the tables you want to see. Test the
connection/data visualization from the same computer with other
applications, such as uDig or QGIS.
Regarding ticket #530:
Keep in mind, I'm not entirely convinced this is a completely valid
issue due to the limited extent of testing. It may work with recent
versions of PostGIS on a Windows platform, for instance.
-Mike
Jackie Ng wrote:
> Your PostGIS may be too new for the provider
> http://trac.osgeo.org/fdo/ticket/530
> - Jackie
> thabet084 wrote:
>> Hi all
>> I used the most recent
>> 1- MapGuide 2.1.0 Beta
>> 2- FDO PostGIS provider OSGeo.PostGIS.3.4
>> 3- PostGIS 1.3.6
>> 4- MapGuide Maestro 1.0.9.15910
>> I created dataconnection when I created layer the I refer it to the
>> resource Meassage appear to me
>> Failed to read schema from datasource
>> The operation gave the error message: The remote server returned an error
>> :(559)MgConnectionFailedException
More information about the fdo-users
