[fdo-users] Use Fdo to retrieve data from a USGS ASCII DEM file
semis semis2006 at gmail.com
Mon Jul 13 03:32:38 EDT 2009
I'm a new gay for Fdo, I'm very excited that Fdo can connect to so many
formats of GIS files. But I also have some problem when I use Fdo to process
the USGS ASCII DEM files.
In the first step, I can open the connection to GDAL provider successfully.
Then I also can read schema information and the class information, the names
of schema and class are all "default". The default class has two properties,
"FeatureId" and "Raster". But how can I get other information from the
raster file, such as elevation value? Is the information contained in the
Raster property? If so, how can I get the information from it? Should I
create a new schema for this kind of file?
I saw that the data in Raster property is a bytes array when the "Select"
command is executed, and the RasterModelType is RasterDataModelType_Gray,
how can I convert this byte array to a Bitmap? I found that the BitsPerPixel
property in Raster is 16, and I set R, G, B value in the new Bitmap to the
first 8 bits, then I get an ugly bitmap. How do I use the following 8 bits?
Any comments and ideas will be much appreciated!
Thanks in advance!
semis
View this message in context: http://n2.nabble.com/Use-Fdo-to-retrieve-data-from-a-USGS-ASCII-DEM-file-tp3249308p3249308.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users mailing list
