[fdo-users] FDO OGR Provider + Mapguide
psergio
psergio at mediaprimer.pt
Tue Jul 14 12:42:26 EDT 2009
Hello Traian
I'm having problems with the OGR provider.
It happens that the geometry that I have in my database (PostGis) are not
beeing displayed in the right position in MapGuide.
Example: in my database I have a point with coordinates -63949,495217;
15467,134032; 0 but on MapGuide it’s displayed in -64008,282557;
15291.623095; 0.
The System coordinate in Mapguide is Datum73.ModPortgGrd and in PostGis I
use EPSG: 27492.
Have you noticed some issue like that?
Best regards,
Paulo
Traian Stanev wrote:
> Hi Paulo,
> The OGR provider uses locale-dependent string conversion, so that's why
> it's probably not working ok for pure UTF-8. I recompiled the DLL with a
> different string conversion call, and posted it at:
> http://13-9.com/OGRProvider-3.3-utf8.zip
> Give that one a try, it should handle UTF-8 correctly -- but I did not
> test it personally, because I don't have enough time today.
> Traian
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org
> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of psergio
> Sent: Monday, February 09, 2009 12:05 PM
> To: fdo-users at lists.osgeo.org
> Subject: [fdo-users] UTF-8 + FDO OGR Provider + Mapguide
> Hi all,
> I'm using the FDO OGR provider to connect Mapguide to my PostGreSQL 8.3 +
> Postgis database.
> The database encoding is UTF-8, but when i put the data in the map, the
> tooltips and the labels are displaying with incorrect characters.
> Did FDO OGR provider DLL have any issue with the UTF-8 encoding or i
> forgot
> something!?
> Thanks for your time.
> Best regards,
> Paulo
> http://n2.nabble.com/UTF-8-%2B-FDO-OGR-Provider-%2B-Mapguide-tp2298306p2298306.html
> Sent from the FDO Users mailing list archive at Nabble.com.
> fdo-users mailing list
> http://lists.osgeo.org/mailman/listinfo/fdo-users
View this message in context: http://n2.nabble.com/UTF-8-%2B-FDO-OGR-Provider-%2B-Mapguide-tp2298306p3257888.html
More information about the fdo-users
