[fdo-users] AutoCAD Map3D and Oracle FDO Issues
Tony
techswami at hotmail.com
Fri Jun 12 15:27:57 EDT 2009
guys
thanks for discussion , I think we have to have the solution for this. lot
of people are suing MGSO-oracle and Autocad map as there solution sort of
enterprise where data can be centrally located.
i think FDO needs to check the source geometry. i dont think autodesk even
know this issue exist. i have send them many email but did not got any
response. Mike i and planning to use your solution and give it a try . i
will keep you posted
Martin Morrison wrote:
> Mike,
> My reference was to the question about triggers...not the type of
> geometry.
> Martin
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org
> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Mike Toews
> Sent: Friday, June 12, 2009 2:21 PM
> To: FDO Users Mail List; FDO Internals Mail List
> Subject: Re: [fdo-users] AutoCAD Map3D and Oracle FDO Issues
> This issue requires a database-end workaround, which varies depending on
> DB software.
> That said, who is at fault? Is it an issue with AutoCAD Map3D or FDO? If
> it is an AutoCAD issue, should FDO be responsible for inserting/updating
> the same geometry type as the feature source? Is AutoCAD intentionally
> mixing single and mixed geometries, and is this allowed among some or
> all providers? I never bothered submitting at ticket on this issue since
> I wasn't sure what exactly the issue was and who to blame.
> -Mike
>> It's not an AutoCAD/FDO function, it's an Oracle database function. Read
>> up on the triggers in the Oracle docs.
>> Martin
>> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Tony
>> Sent: Friday, June 12, 2009 1:59 AM
>> To: fdo-users at lists.osgeo.org
>> Mike
>> thanks in millions for answer. could you tell me how to implement the
>> trigger from autocad insert.
>> i am new to autocad .
>> thanks
>> tony
>> Mike Toews wrote:
>>> Tony,
>>> I think I had a similar problem, although I'm using Map3D 2008/2010 with
>>> a PostgreSQL/PostGIS database. The issue was Map3D was creating and
>>> sending a [single] POLYGON object to a MULTIPOLYGON column, which it
>>> shouldn't, since the column has check constraints to ensure they are all
>>> MULTIPOLYGON geometries. I fixed it by writing a simple BEFORE INSERT OR
>>> UPDATE trigger to check and correct if the polygon is a multi object.
>>> I'm no pro with Oracle spatial, but the guts of my PL/pgSQL (with
>>> PostGIS) trigger function look somthing like this:
>>> IF ST_GeometryType(NEW.geometry) IN('POLYGON','LINESTRING') THEN
>>> NEW.geometry := ST_Multi(NEW.geometry);
>>> END IF;
>>> I think most of this is portable to your situation, except that
>>> ST_GeometryType() returns different values. I'm not sure if there is a
>>> generic ST_Multi() function, but there are similar casts that you can
>>> use.
>>> Hope this helps,
>>> -Mike
>>> Tony wrote:
>>>> i am using fdo (autodesk) as well as used king fdo for getting the CAD
>>>> data
>>>> write to oracle.
>>>> here is the whole story : i have a polygon shape file i have used
>>>> FDO2FDO
>>>> to
>>>> create oracle table , I want to edit some of geometries in AutoCADmap
>>>> 3D
>>>> as
>>>> well as i want to add new polygons there.
>>>> the issue: i have createa a closed polygon in autocadmap that have Arc
>>>> and
>>>> line and i was trying to write this to the above created table. i am
>>>> getting error saying that geometry type does not match,
>>>> after reading the logs i found out that though my Oracle table has
>>>> mpolygon
>>>> geometry type i can not write and polygon with Arc(true arc) in it.
>>>> any idea how to solve this issue. i have wote to autodesk and still
>>>> wating
>>>> to get the answer. i wrote to king fdo no reply yet ...
>>>> please let me know how to solve this
>>> fdo-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/fdo-users
View this message in context: http://n2.nabble.com/AutoCAD-Map3D-and-Oracle-FDO-Issues-tp3065246p3069509.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users
