[fdo-users] FDO and Autocad Map 2009
Martin Morrison
martin.morrison at edsi.com
Tue Jun 16 15:28:24 EDT 2009
Keep in mind I'm not a lawyer. From the license agreement...
3.2.6 Modifications. You may not modify, translate, adapt, arrange, or create derivative works based on the Autodesk Materials for any purpose.
I would consult with someone from Adesk to find out how FDO applies to the above section of the license agreement. Maybe one of the Adeskers can chime in here.
Martin
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Brad Nesom
Sent: Tuesday, June 16, 2009 3:02 PM
To: 'FDO Users Mail List'
Subject: RE: [fdo-users] FDO and Autocad Map 2009
Keeping a copy of the FDO folder constitutes no legal or technical difficulties.
FDO is open source and there is no technical difficulty. When you open autocad map it reads the FDO directory to load the data providers listed in the providers list.
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Martin Morrison
Sent: Tuesday, June 16, 2009 11:16 AM
To: FDO Users Mail List
I don't think you can do that. Both technical and legal issues come to mind.
Martin
Sent: Tuesday, June 16, 2009 10:00 AM
I am sure that someone more qualified will respond with the exact version capabilities. My response is; always keep a copy of the existing in another location in the case you need to go back to it.
Brad
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of brujulas
Sent: Tuesday, June 16, 2009 8:52 AM
To: fdo-users at lists.osgeo.org
Subject: [fdo-users] FDO and Autocad Map 2009
Hi, I want to know if is possible to replace the version by default of FDO in Autocad Map... Map 2009 has installed the version 3.3.0, could I to replace this version to 3.4.0?? Greatings.
View this message in context: FDO and Autocad Map 2009<http://n2.nabble.com/FDO-and-Autocad-Map-2009-tp3086464p3086464.html>
Sent from the FDO Users mailing list archive<http://n2.nabble.com/FDO-Users-f2048584.html> at Nabble.com.
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20090616/81a62094/attachment-0001.html
More information about the fdo-users
