[fdo-users] FDO spatial query
bebeto
betak at softplan-slovakia.sk
Tue Mar 10 05:22:31 EDT 2009
And any idea for some library which can do such postprocessing? Have checked
JTS suite but does not support curvestrings :(
Dan Stoica wrote:
> The short answer is: no, you cannot solve the problem without post
> processing the points.
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org
> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of bebeto
> Sent: Monday, March 09, 2009 1:00 PM
> To: fdo-users at lists.osgeo.org
> Subject: [fdo-users] FDO spatial query
> hi, I need to create FDO query to return set of points in specific order.
> To explain problem easiest way - imagine you have predefined route (line)
> and want to return list gas stations (points) along that route with
> nearest
> first.
> Only solution I was able to create was FDO_SELECT command with
> SpatialOperations.SpatialOperations_Intersects filter
> (usually they are in some short distance to this line, but make it
> simplier
> and assume points are exactly on line)
> collection of points returned was ok, but in random order.
> Any ideas (even with different technology like FDO) how to solve this are
> welcome. My goal is to manage geometry only with using some library and do
> not write complex algorithms dealing with different geom. types like
> linestring curvestring etc.
> http://n2.nabble.com/FDO-spatial-query-tp2450209p2450209.html
> Sent from the FDO Users mailing list archive at Nabble.com.
> fdo-users mailing list
> http://lists.osgeo.org/mailman/listinfo/fdo-users
View this message in context: http://n2.nabble.com/FDO-spatial-query-tp2450209p2454115.html
More information about the fdo-users
