[fdo-users] RE: ESRI File Geodatabases
Brad Nesom
kidsmake6 at msn.com
Thu Mar 12 09:56:53 EDT 2009
Not sure what I am doing wrong.
I have the provider dll you sent in the fdo bin directory. I get a successfull connection but when I add it to the map it says
failed to cache features
geometry is null.
I have tried this with several pgdb's that I have verified do work in esri software.
Brad
> From: traian.stanev at autodesk.com
> To: fdo-users at lists.osgeo.org
> Date: Tue, 10 Mar 2009 07:21:55 -0700
> Subject: RE: [fdo-users] RE: ESRI File Geodatabases
> I already posted it but forgot to send an email.
> http://13-9.com/OGRProvider-3.3-nopq.zip
> Write support does not depend on the provider, but on the underlying OGR driver, so I am the wrong person to ask about that.
> Traian
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Brad Nesom
> Sent: Tuesday, March 10, 2009 10:12 AM
> To: 'FDO Users Mail List'
> Thanks Traian,
> If you don't mind I would like the newly compiled dll.
> Brad
> Is there any plan to make a read/write version?
> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Traian Stanev
> Sent: Monday, March 09, 2009 9:28 AM
> The provider dll I posted is compiled with postgis support, which requires
> an external dll from Postgres (libpq.dll), which is likely what you are
> missing. I could probably recompile without that and post a new one, later
> today. (Or you could get the libpq.dll and its dependencies from a Postgres
> package).
> The provider I posted is compiled with ODBC support as well, which is what
> you are missing from the one that comes with the FDO package. It's really
> the default build of the GDAL dll that has that missing, and the one I
> posted is statically linked to a build of GDAL with ODBC enabled. I have
> tried it with geodatabases in the past, in Map3D, and it definitely works,
> once you can load the provider. :)
> Traian
> Sent: Monday, March 09, 2009 10:19 AM
> Traian,
> I have since my last post downloaded the dll provided in your last post. I
> removed the 3.3.2 fdo and re-loaded the 3.3.0 from the original autodesk
> install. At that point I noticed there was no ogr provider in the original.
> So I added the following to my providers.xml
> <FeatureProvider>
> <Name>OSGeo.OGR.3.3</Name>
> <DisplayName>OSGeo FDO Provider for OGR </DisplayName>
> <Description>Read access to OGC OGR-based data store. </Description>
> <IsManaged>False</IsManaged>
> <Version>3.3.0.0</Version>
> <FeatureDataObjectsVersion>3.3.0.0</FeatureDataObjectsVersion>
> <LibraryPath>OGRProvider.dll</LibraryPath>
> </FeatureProvider>
> And place the ogrprovider.dll in my fdo/bin folder. When I start map I get
> the error stack following...
> <?xml version="1.0" ?>
> - <Map3dErrorLog xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xsi:noNamespaceSchemaLocation="AcMap3dErrorLog.xsd">
> - <Session user="ws21" start="3/9/2009 9:18:51 AM" document="Drawing1.dwg">
> - <Error code="1" type="15" dispensation="1" sId="2" occurrence="1">
> Failed to load connection control for provider. Either the provider is not
> installed or there was an error accessing it.
> <Entry code="1" type="15" sId="3" occurrence="1">Unable to create
> connection to provider 'OSGeo.OGR.3.3'</Entry>
> <Entry code="1" type="15" sId="4" occurrence="1">Unable to load the FDO
> Provider: The specified module could not be found.</Entry>
> <Entry code="1" type="15" sId="5" occurrence="1">Failed to load connection
> control for provider. Either the provider is not installed or there was an
> error accessing it.</Entry>
> <Entry code="1" type="15" sId="6" occurrence="1">Unable to create
> <Entry code="1" type="15" sId="7" occurrence="1">Unable to load the FDO
> </Error>
> </Session>
> </Map3dErrorLog>
> Sent: Monday, March 09, 2009 7:30 AM
> No, the 3.3.0 version I am using is the shipped with and installed with
> autodesk map 3d 2009.
> At this time I have the 3.3.2 version installe from the fdo downloads...
> http://fdo.osgeo.org/content/fdo-332-downloads
> Windows SDK
> The following tar files contains the Windows (32 bit) Managed and Unmanaged
> FDO SDK files, including binaries, libraries and header files.
> fdosdk-win32-3.3.2.tar.gz
> Sent: Friday, March 06, 2009 5:55 PM
> To: FDO Users Mail List
> Which OGRProvider.dll are you using -- the one I posted at the URL below?
> http://13-9.com/OGRProvider-3.3.0.zip
> Traian
> ________________________________________
> From: fdo-users-bounces at lists.osgeo.org [fdo-users-bounces at lists.osgeo.org]
> On Behalf Of Brad Nesom [kidsmake6 at msn.com]
> Sent: Friday, March 06, 2009 5:51 PM
> Traian,
> I am unable to accomplish even read only of the MDB in 3.3.0 or 3.3.2.
> Also the documentation shows that is it read/write.
> http://fdo.osgeo.org/OSProviderOverviews.html
> OSGeo FDO Provider for OGR<http://fdo.osgeo.org/fdoogr/index.html>
> OGR is a open source library. Read and write access is provided to vector
> data from the OGR library
> Sent: Friday, March 06, 2009 9:10 AM
> Subject: [fdo-users] RE: ESRI File Geodatabases
> Hi David,
> If you are talking about the personal geodatabase, that's in MDB format -
> you can read those with the OGR provider, in both 3.3 and 3.4. Note that
> support is read only.
> Traian
> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of David Anderson
> Sent: Thursday, March 05, 2009 3:14 PM
> Subject: [fdo-users] ESRI File Geodatabases
> Does 3.3 or 3.4 support the ESRI file geodatabase?
> Thanks,
> David Anderson, P.E.
> Donnell & Allred, Inc.
> 908 Big Horn Ave
> P.O. Box 638
> Worland, WY 82401
> 307-347-8276
> 307-347-8277 fax
> da at donnellandallred.com<mailto:da at donnellandallred.com>
> fdo-users mailing list
> http://lists.osgeo.org/mailman/listinfo/fdo-users
_________________________________________________________________
Windows Live™ Groups: Create an online spot for your favorite groups to meet.
http://windowslive.com/online/groups?ocid=TXT_TAGLM_WL_groups_032009
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20090312/a2a20b6f/attachment.html
More information about the fdo-users
