[fdo-users] ESRI File Geodatabases
Brad Nesom
kidsmake6 at msn.com
Fri Mar 13 12:11:26 EDT 2009
Thanks for the clarification Crispin!
I have been using the format - ODBC:myconnectionname
I bet that will make a difference.
Brad
-----Original Message-----
[mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Crispin_at_1Spatial
Sent: Friday, March 13, 2009 8:01 AM
To: fdo-users at lists.osgeo.org
Subject: RE: RE: [fdo-users] ESRI File Geodatabases
OK,
I have tried this DLL in AutoCAD Map 2009 SP1 and also in our alternative
MapRelate solution.
Success on both camps - especially pleased with this build including xerces
support means that I can read GML into AutoCAD now! Thanks Trian.
The sample GeoDatabase I am using came from the interweb somewhere and to
utilise the personal geodatabase I first created a System-ODBC connection to
the MDB file in the Windows ODBC administrator - in my case I called my
sample ODBC connection 'pgeo_somerset'.
Then in Map I did a 'Add OGR Connection' and in the box for datasource put
this exact format (from the OGR documentation) - ie the "PGeo:" prefix and
then the ODBC connection name:
PGeo:pgeo_somerset
I hope this helps.
Crispin
View this message in context:
http://n2.nabble.com/ESRI-File-Geodatabases-tp2431900p2473261.html
Sent from the FDO Users mailing list archive at Nabble.com.
fdo-users mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users
