[fdo-users] finally
doggybs
james.slater at keynetix.com
Tue May 19 08:19:22 EDT 2009
That is good news! I think I have been casing this problem for a while, when
mapguide will lockup and crash when multiple users are viewing data from the
postgis FDO.
Would it be possible for you to give some more details on how to setup the
work arounds you have suggested.
Many Thanks
James
Haris Kurtagic wrote:
> Finally we found what was causing MapGuide server to crash while reading
> data from MapGuide.
> It took us lot of energy and time.
> Problem will appear in multiuser environment with concurent access when
> you are using provider which is per command threaded or sharing
> (caching) FDO schema accross multiple connections.
> Issue is in function:
> MgServerGetFeatures::SerializeToXml(FdoClassDefinition* classDef) which
> will in order to serialize class to xml remove that class from schema,
> put it to temporary schema serialize and return class to original
> schema. While doing this if another thread goes to execute, problem
> starts.
> Workaround is to set provider to per connection threaded or not cache
> schema at all, and both comes with perfomance penalties.
> I think that few things are important in this case beside the obvious
> issue. One of them is missing constant pointers in FDO API. Schema
> returned from provider shouldn't be allowed to be changed by fdo
> clients. That is something were problems appeared already.
> Also, I think that serialization using XML is not right way to go. XML
> we could use to serialize data to end-user not for internal MG
> processes.
> Haris
> fdo-users mailing list
> fdo-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-users
View this message in context: http://n2.nabble.com/finally-tp2939043p2939178.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users
