[fdo-users] Memory problem with ArcSDEProvider92.dll
Fuji Deng
big_willion at 163.com
Sun May 31 20:53:17 EDT 2009
I tried to use ArcSDEProvider92.dll (It’s file version number is
3.4.0.0), I encounted a memory leak problem.
The test environment:
1. The application is running in WindowsXP with the latest updates.
2. The application is compiled by Visual Studio 2008 SP1.
3. SQL-Server 2008 And ArcSDE9.2 in Windows 2003 SP2 with almost the latest
updates.
4. About ArcSDEProvider92.dll, I test both the file downloaded from website
and compile by source codes.
There’s the test sample codes at the end of this post.
I set 2 breakpoints in the _tmain function, one is at the “for (int i = 0; i
< 100; i++)”, the other one is at the “return 0;” The difference of memory
usage between these 2 breakpoints is about 60 MB, that means there’re 60 MB
memory not released.
In each loop, there’re about 300 shapes be read, those shapes are simple
polygons, each polygon contains about 5-10 points.
I tried to release the all resources in the “for” loop, but it seems
there’re still some memory not released.
Do I miss something when try to release memory? Or is it the
ArcSDEprovider92.dll issue?
#include "stdafx.h"
#include "string.h"
#include <Windows.h>
#include "Fdo/Connections/IConnection.h"
#include "Fdo/Commands/CommandType.h"
#include "Fdo/Commands/ICommand.h"
#include "Fdo/Commands/IFeatureCommand.h"
#include "Fdo/Commands/Feature/ISelect.h"
#include "Geometry/Fgf/Factory.h"
#include "Common/Array.h"
typedef FdoIConnection* (*CreateConnectionProc)();
#ifdef _WIN32
#ifndef ARCSDEPROVIDER_EXPORTS
#define FDOSDE_API __declspec(dllexport)
#else
#define FDOSDE_API __declspec(dllimport)
#endif
#endif
class ArcSDELoaderLibrary
private:
HMODULE m_hArcSDE;
public:
ArcSDELoaderLibrary()
m_hArcSDE = NULL;
try
HMODULE hmod = ::LoadLibraryW(L"sde.dll");
if (hmod != NULL)
::FreeLibrary(hmod);
m_hArcSDE = ::LoadLibraryW(L"ArcSDEProvider92.dll");
// in case load ArcSDEProvider92.dll fails try to load 91
if (m_hArcSDE == NULL)
m_hArcSDE = ::LoadLibraryW(L"ArcSDEProvider91.dll");
else
catch(...){}
HMODULE GetLibraryHandle()
return m_hArcSDE;
~ArcSDELoaderLibrary()
try
if (m_hArcSDE != NULL)
::FreeLibrary(m_hArcSDE);
catch(...){}
static ArcSDELoaderLibrary arcSDEloader;
// external access to connection for client services
extern "C" FDOSDE_API FdoIConnection* CreateConnection ()
CreateConnectionProc procCreateConn;
HMODULE hArc = arcSDEloader.GetLibraryHandle();
if (hArc != NULL)
procCreateConn = (CreateConnectionProc)::GetProcAddress (hArc,
"CreateConnection");
if (procCreateConn != NULL)
return procCreateConn();
return NULL;
int _tmain(int argc, _TCHAR* argv[])
FdoIConnection* connection = CreateConnection();
FdoString* connectionString =
L"Server=serverIP;Instance=5151;Username=username;Password=password;Datastore=datastore";
FdoFgfGeometryFactory* factory =
FdoFgfGeometryFactory::GetInstance();
connection->SetConnectionString(connectionString);
FdoConnectionState state = connection->Open();
for (int i = 0; i < 100; i++)
FdoISelect* command =
(FdoISelect*)connection->CreateCommand(FdoCommandType_Select);
command->SetFeatureClassName(L"TableName");
command->SetFilter(L"Shape ENVELOPEINTERSECTS
GeomFromText(‘Wkt of the specify extent.')");
FdoIFeatureReader* reader = command->Execute();
while (reader->ReadNext())
FdoByteArray* ba =
reader->GetGeometry(L"ShapeColumnName");
FdoIGeometry* geometry =
factory->CreateGeometryFromFgf(ba);
ba->Release();
geometry->Release();
reader->Release();
command->Release();
connection->Release();
factory->Release();
return 0;
View this message in context: http://n2.nabble.com/Memory-problem-with-ArcSDEProvider92.dll-tp3003984p3003984.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users
