[fdo-users] Insert new feature object on SHP File
Gavin Cramer
gavin.cramer at autodesk.com
Mon Nov 2 00:51:27 EST 2009
It is good to see that you got your code working.
I noticed that you were providing a value for the ID property. In SHP, I believe that the identifier is always auto-generated. Perhaps the SHP Provider is not checking, but some providers are more strict and may throw an exception if you supply a value for an auto-generated property.
To find out whether a property is auto-generated, you can use the FdoIDescribeSchema command, and search the resulting object tree for the needed property. The FdoDataPropertyDefinition:: GetIsAutoGenerated() method will say whether the property is auto-generated (in which case, it is best to not provide a value during an Insert).
Gavin
-----Original Message-----
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Matteo
Sent: Sunday, November 01, 2009 4:39 PM
To: fdo-users at lists.osgeo.org
Subject: Re: [fdo-users] Insert new feature object on SHP File
Thanks a lot Jason. Now work fine.
Regards,
Matteo
Jason Birch wrote:
> I'm not an FDO coder, but there are a couple things I'd look at.
> First, FDODimensionality isn't an integer value representing the number of
> dimensions, it's a bit-field enumeration. In this case, 2 evaluates to
> FdoDimensionality_M (although, since the value of FdoDimensionality_XY is
> 0,
> this is included by default in the evaluation of FdoDimensionality_M -
> neat).
> http://fdo.osgeo.org/files/fdo/docs/FDO_API/d3/d95/group__enums_g3778ef9845e2ba00e8669c32ec42e113.htm#g3778ef9845e2ba00e8669c32ec42e113
> Second, the docs for CreateLineString indicate that it's looking for the
> number of ordinates, not co-ordinates. I'm not sure if this is just a
> terminology issue, but perhaps it is looking for 6 in your case.
> http://fdo.osgeo.org/files/fdo/docs/FDO_API/d1/d7d/class_fdo_fgf_geometry_factory_0e122ad008ada729f974e407aa1285dd.htm#0e122ad008ada729f974e407aa1285dd
> Jason
> 2009/11/1 Matteo <matteo.conte1979 at libero.it>
>> Hi all,
>> I'm new on FDO. I try to insert a new feature object on a shp file with
>> VB.NET but i get this error "The type of geometry ( 'PolyLineM')
>> geographical entity creates a conflict with the type of shape file (
>> 'Polyline')."
>> This is the code:
>> Dim objCmdI As Commands.Feature.IInsert =
>> objConn.CreateCommand(Commands.CommandType.CommandType_Insert)
>> objCmdI.SetFeatureClassName(objClass.Name)
>> Dim objPropsValues As Commands.PropertyValueCollection =
>> objCmdI.PropertyValues()
>> Dim objPropV As Commands.PropertyValue = New
>> Commands.PropertyValue()
>> objPropV.SetName("ID")
>> objPropV.Value = New OSGeo.FDO.Expression.Int32Value(2)
>> objPropsValues.Add(objPropV)
>> objPropV = New Commands.PropertyValue()
>> objPropV.SetName("Geometry")
>> Dim objGeomV As Geometry.FgfGeometryFactory = New
>> Geometry.FgfGeometryFactory()
>> Dim objCoords(5) As Double
>> objCoords(0) = 0
>> objCoords(1) = 0
>> objCoords(2) = 10
>> objCoords(3) = 10
>> objCoords(4) = 50
>> objCoords(5) = 20
>> Dim objLine As Geometry.ILineString = objGeomV.CreateLineString(2,
>> 3, objCoords)
>> OSGeo.FDO.Expression.GeometryValue(objGeomV.GetFgf(objLine))
>> objCmdI.Execute()
>> objConn.Flush()
>> Can you help me?
>> Regards,
>> Matteo
>> View this message in context:
>> http://n2.nabble.com/Insert-new-feature-object-on-SHP-File-tp3928348p3928348.html
>> Sent from the FDO Users mailing list archive at Nabble.com.
>> fdo-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/fdo-users
View this message in context: http://n2.nabble.com/Insert-new-feature-object-on-SHP-File-tp3928348p3928709.html
More information about the fdo-users
