[fdo-users] FDO Compile error (libxalan-c)
kernel_panic
sudoaptgetinstalld00d3 at gmail.com
Sat Nov 7 13:41:23 EST 2009
Finally!!!!!!!!!!!!!
build_oem.sh succeeded!!!
Implanning to write a how-to once I double-check everything from a
clean install, but I cant quite say "victory" so far...
when I run the ./configure script, I find that there arent ANY
Makefile.in files on any folder... so I have to manually search, copy,
paste and rerun the script to tell me which Makefile.in is missing and
where...
I think this is a serious mistake, why werent they, eiher genereated
while building OEM or by the devs in charge...
I think this could be called a "reggresion" because the latest stable
mapguide traball didnt have this problem, and in fact, Im copying the
.in files from the tarball... but they're simply TOO MUCH of them :p:p
Can someone fix the makefile.in issue? :p:p
More information about the fdo-users
