[fdo-users] Create SHP file
Jackie Ng
jumpinjackie at gmail.com
Mon Nov 9 07:01:20 EST 2009
Creating shape files is a special case in FDO. What you do is bascially
connect to a directory of your choice, and then execute an IApplySchema
command. A shape file will be created for every feature class inside the
schema that is being applied.
Hope that helps.
- Jackie
sekko970 wrote:
> Hi all,
> I need to create a shape file programmatically in an ASP.NET application:
> is it possible using FDO API?
> If no, how is it possible to personalize the structure of an existing
> empty shape file, always using FDO API?
> An examples of the APIs to use should be very evaluable.
> Thanks,
> F.
View this message in context: http://n2.nabble.com/Create-SHP-file-tp3972526p3972551.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users
