[fdo-users] FDO Compile error (libxalan-c)
Traian Stanev
traian.stanev at autodesk.com
Tue Oct 6 16:44:07 EDT 2009
If you are using the latest Ubuntu and the latest FDO sources, your best bet is probably to try the CMake build system instead of the automake based one. That of course depends on which FDO providers you need, since some of them don't have CMake files yet.
Traian
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-
> bounces at lists.osgeo.org] On Behalf Of kernel_panic
> Sent: Tuesday, October 06, 2009 4:42 PM
> To: FDO Users Mail List
> Subject: Re: [fdo-users] FDO Compile error (libxalan-c)
> Well, Im not having this particular issue:
> 2009/10/6, john spitzer <john.spitzer at gmail.com>:
> > Hi,
> > When building FDO from source on Ubuntu I got the following g++
> > compile time issue:
> > g++ -O2 -DNDEBUG -fno-elide-constructors -Wall -fPIC -DLINUX
> > -D_REENTRANT -DXALAN_INMEM_MSG_LOADER -c
> > -I/home/jjs/OpenSource_FDO/Thirdparty/apache/xml-xalan/c/src
> > -I/home/jjs/OpenSource_FDO/Thirdparty/apache/xml-xalan/c/include
> > -I../../nls/include
> > -I/home/jjs/OpenSource_FDO/Thirdparty/apache/xml-xerces/c/src/
> > -I/home/jjs/OpenSource_FDO/Thirdparty/apache/xml-xerces/c/include/xercesc
> > -I/home/jjs/OpenSource_FDO/Thirdparty/apache/xml-xerces/c/include/ -o
> > ../../obj/XalanDOMString.o
> xalan/c/src/xalanc/XalanDOM/XalanDOMString.cpp
> xalan/c/src/xalanc/XalanDOM/XalanDOMString.cpp:
> > In member function 'xalanc_1_7::XalanDOMString&
> > xalanc_1_7::XalanDOMString::assign(const xalanc_1_7::XalanDOMString&,
> > size_t, size_t)':
> xalan/c/src/xalanc/XalanDOM/XalanDOMString.cpp:281:
> > error: 'memmove' is not a member of 'std'
> > In static member function 'static size_t
> > xalanc_1_7::XalanDOMString::length(const char*)':
> xalan/c/src/xalanc/XalanDOM/XalanDOMString.cpp:825:
> > error: 'strlen' is not a member of 'std'
> > In function 'bool xalanc_1_7::doTranscodeFromLocalCodePage(const
> > char*, size_t, bool, xalanc_1_7::XalanDOMCharVectorType&, bool)':
> xalan/c/src/xalanc/XalanDOM/XalanDOMString.cpp:1154:
> > error: 'strncpy' is not a member of 'std'
> > make[1]: *** [../../obj/XalanDOMString.o] Error 1
> > make[1]: Leaving directory
> > `/home/jjs/OpenSource_FDO/Thirdparty/apache/xml-xalan/c/src/xalanc'
> > make: *** [all] Error 2
> But adding #include <cstring> on all .cpp files on
> /Thirdparty/gdal/frmts/ilwis/ made another (unnoticed :p) error go
> away, regarding libgdal.so not being created.
> However, Im still getting the xalan error :S
> "make[1]: se sale del directorio `/opt/fdo-3.3.1/Thirdparty/gdal/apps'
> make[1]: se ingresa al directorio `/opt/fdo-3.3.1/Thirdparty'
> make[1]: *** No hay ninguna regla para construir el objetivo
> `apache/xml-xalan/c/lib/libxalan-c.so.17.0', necesario para `all-am'.
> Alto.
> make[1]: se sale del directorio `/opt/fdo-3.3.1/Thirdparty'
> make: *** [install-recursive] Error 1"
> I was thinking on what you said about passing variables between
> scripts, but I dont know how the scripts are run :p, I mean, I dont
> know who calls who, so I dont know where to look for...
> Does anyone know in which order the scripts are run, or how can I
> figure out that?
> fdo-users mailing list
> fdo-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users
