[fdo-users] FDO Compile error (libxalan-c)
Traian Stanev
traian.stanev at autodesk.com
Tue Oct 6 17:18:50 EDT 2009
I meant 3.5, not 3.4. :)
I have compiled successfully on Ubuntu using both automake and CMake, but I don't remember all the hacks I had to do to make it work using the automake build (it was a while back). The pain you are seeing with Thirdparty is that the versions of the components in /Thirparty are old and will not compile with newer g++. The CMake build uses the versions of those libraries installed by Ubuntu itself (using apt-get), so it does not have to compile /Thirparty at all. There is a file in /trunk/ called CMake__README.txt which explains how to do it.
Traian
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-
> bounces at lists.osgeo.org] On Behalf Of kernel_panic
> Sent: Tuesday, October 06, 2009 4:55 PM
> To: FDO Users Mail List
> Subject: Re: [fdo-users] FDO Compile error (libxalan-c)
> Well, right now Im using 3.3.1, but I might give 3.4.0 a go :)
> Now, I have some more questions :)
> a) Have you compiled FDO succesfully on ubuntu (or anything
> debian-based)? if so, which version, and how did you do it?
> b) Do you know which FDO providers work with CMake build system?
> c) How do I try using CMake? :p. Never been there, never done that :p
> 2009/10/6, Traian Stanev <traian.stanev at autodesk.com>:
> > Hi,
> > If you are using the latest Ubuntu and the latest FDO sources, your best
> bet
> > is probably to try the CMake build system instead of the automake based
> one.
> > That of course depends on which FDO providers you need, since some of them
> > don't have CMake files yet.
> > Traian
> >> Sent: Tuesday, October 06, 2009 4:42 PM
> >> Well, Im not having this particular issue:
> >> 2009/10/6, john spitzer <john.spitzer at gmail.com>:
> >> > Hi,
> >> > When building FDO from source on Ubuntu I got the following g++
> >> > compile time issue:
> >> > g++ -O2 -DNDEBUG -fno-elide-constructors -Wall -fPIC -DLINUX
> >> > -D_REENTRANT -DXALAN_INMEM_MSG_LOADER -c
> >> > -I/home/jjs/OpenSource_FDO/Thirdparty/apache/xml-xalan/c/src
> >> > -I/home/jjs/OpenSource_FDO/Thirdparty/apache/xml-xalan/c/include
> >> > -I../../nls/include
> >> > -I/home/jjs/OpenSource_FDO/Thirdparty/apache/xml-xerces/c/src/
> xerces/c/include/xercesc
> >> > -I/home/jjs/OpenSource_FDO/Thirdparty/apache/xml-xerces/c/include/ -o
> >> > ../../obj/XalanDOMString.o
> >> xalan/c/src/xalanc/XalanDOM/XalanDOMString.cpp
> >> xalan/c/src/xalanc/XalanDOM/XalanDOMString.cpp:
> >> > In member function 'xalanc_1_7::XalanDOMString&
> >> > xalanc_1_7::XalanDOMString::assign(const xalanc_1_7::XalanDOMString&,
> >> > size_t, size_t)':
> >> xalan/c/src/xalanc/XalanDOM/XalanDOMString.cpp:281:
> >> > error: 'memmove' is not a member of 'std'
> >> > In static member function 'static size_t
> >> > xalanc_1_7::XalanDOMString::length(const char*)':
> >> xalan/c/src/xalanc/XalanDOM/XalanDOMString.cpp:825:
> >> > error: 'strlen' is not a member of 'std'
> >> > In function 'bool xalanc_1_7::doTranscodeFromLocalCodePage(const
> >> > char*, size_t, bool, xalanc_1_7::XalanDOMCharVectorType&, bool)':
> >> xalan/c/src/xalanc/XalanDOM/XalanDOMString.cpp:1154:
> >> > error: 'strncpy' is not a member of 'std'
> >> > make[1]: *** [../../obj/XalanDOMString.o] Error 1
> >> > make[1]: Leaving directory
> >> > `/home/jjs/OpenSource_FDO/Thirdparty/apache/xml-xalan/c/src/xalanc'
> >> > make: *** [all] Error 2
> >> But adding #include <cstring> on all .cpp files on
> >> /Thirdparty/gdal/frmts/ilwis/ made another (unnoticed :p) error go
> >> away, regarding libgdal.so not being created.
> >> However, Im still getting the xalan error :S
> >> "make[1]: se sale del directorio `/opt/fdo-3.3.1/Thirdparty/gdal/apps'
> >> make[1]: se ingresa al directorio `/opt/fdo-3.3.1/Thirdparty'
> >> make[1]: *** No hay ninguna regla para construir el objetivo
> >> `apache/xml-xalan/c/lib/libxalan-c.so.17.0', necesario para `all-am'.
> >> Alto.
> >> make[1]: se sale del directorio `/opt/fdo-3.3.1/Thirdparty'
> >> make: *** [install-recursive] Error 1"
> >> I was thinking on what you said about passing variables between
> >> scripts, but I dont know how the scripts are run :p, I mean, I dont
> >> know who calls who, so I dont know where to look for...
> >> Does anyone know in which order the scripts are run, or how can I
> >> figure out that?
> >> _______________________________________________
> >> fdo-users mailing list
> >> fdo-users at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users
