[fdo-users] MapGuide MapGuide 2.1.0 (Beta) with PostGIS provider
Dejan Gregor dejan.gregor at GMAIL.COM
Fri Oct 23 03:32:51 EDT 2009
So you are saying that ...
- PostGIS 1.3.4 or 1.3.3. should be used with PostGRESQL 8.3.7 ?
Should I replace the FDO for MapGuide 2.0.2 / 2.1 that come along the
Windows installation with some other?
I would very much appreciate any suggestions, tips and help!
Kind regards,
Dejan Gregor
Bruno Scott wrote:
> I have tested the PostGIS provider with Mapguide 2.1 under this
> configuration
>   Postgres 8.3.7
>   PostGIS 1.3.5
> And using the latest version of the provider available at this address
> http://www.geomapgis.com/web/geomap-group/fdo/index.html
> I'm not sure that the latest build at http://download.osgeo.org/fdo/ are
> up to date.
> My latest checkin was on april 29
> Bruno
> thabet084 wrote:
>> Thank you  Jackie & Mike for your replies,
>> I found error as Jackie reply that  PostGIS version is too new ,then i
>> tell U the package which run correctly with me
>> 1.	MapGuide 2.1.0 (Beta).
>> 2.	postgis-1.3.4 (2008/11/24)
>> 3.	OSGeo.PostGIS.3.4 (means FDO.PostGIS provider).
>> it runs correct.
>> Thank you again Jackie
______________
CGS plus d.o.o.
Brnčičeva ulica 13,
1000 Ljubljana
View this message in context: http://n2.nabble.com/MapGuide-MapGuide-2-1-0-Beta-with-PostGIS-provider-tp3191035p3877275.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users mailing list
