[fdo-users] RE: Trouble connecting Mapguide to Postgis.
Remco Houtkamp
r.houtkamp at burohoutkamp.nl
Wed Sep 23 12:30:34 EDT 2009
I'm behind another machine now on which I installed postgresql 8.3 still no luck.
Does anybody know a setup at winxp that does work. Maybe I can check out the versions that person is running.
-----Oorspronkelijk bericht-----
Van: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] Namens Zac Spitzer
Verzonden: woensdag 23 september 2009 18:08
Aan: FDO Users Mail List
Onderwerp: Re: [fdo-users] RE: Trouble connecting Mapguide to Postgis.
maybe a version mismatch, try using the dll's from 8.3.7.?
On Thu, Sep 24, 2009 at 2:04 AM, Remco Houtkamp
<r.houtkamp at burohoutkamp.nl> wrote:
> All the dll 's are present within C:\Program Files\OSGeo\MapGuide\Server\Fdo
> unfortunately that does not help. I'm out off clues so I hope somebody can
> help...
> Remco
> [mailto:fdo-users-bounces at lists.osgeo.org] Namens Orest Halustchak
> Verzonden: dinsdag 22 september 2009 15:08
> Onderwerp: [fdo-users] RE: Trouble connecting Mapguide to Postgis.
> Hi Remco,
> In addition to libq.dll, there are a number of other dll's from the
> postgresql bin that you can try to copy into the fdo bin directory.
> - comerr32.dll
> - gssapi32.dll
> - k5sprt32.dll
> - krb5_32.dll
> - libeay32.dll
> - libiconv-2.dll
> - libintl-8.dll
> - libpq.dll
> I have not tried postgres 8.4 yet, but I have used postgis 1.3.6 / postgres
> 8.3.7.
> Thanks,
> Orest.
> From: fdo-users-bounces at lists.osgeo.org
> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Remco Houtkamp
> Sent: Tuesday, September 22, 2009 2:46 AM
> To: fdo-users at lists.osgeo.org
> Subject: [fdo-users] Trouble connecting Mapguide to Postgis.
> Hi list,
> Somebody from the mapguide lijst told me about this list so I just
> subscribed. I 'm new to this game and an newbie, but learned a lot the last
> couple of months.
> I finally managed to build the following setup:
> Winxp
> Mapguide 2.1
> Mapguide Maestro
> Postgresql 8.4
> Postgis 1.4
> I've filled the database (postgresql) with data from open street map with
> osm2pgsql. I can connect from Udig to postgis and from Quantum Gis (1.3 !!!
> 1.0 included with osgeo4w is not working). So my postgis setups works.
> In mapguide maestro I go through the following steps:
> Create a new resource>data connection
> OSGEO FDO Provider for Postgis
> Database: osm (is visible in Udig)
> server: I tried localhost http://localhost/ 127.0.0.1 http:// 127.0.0.1/
> Port: 5432
> Tried all three credentials but think it must be Specified Credentials with
> user postgres and my secret password ;)
> Press test connection and then the following error appears:
> De externe server heeft een fout geretourneerd: (559) MgFdoException.: An
> exception occurred in FDO component. Unable to load the FDO Provider: Kan
> opgegeven module niet vinden. (some of this is Dutch... for cannot find the
> module)
> Somebody told me to test the fdo with depends.exe. This way we found out
> that libpq.dll is missing. After installing " a version of libpq.dll" I was
> able to run the the test connection. It returned no errors and I save the
> connection. After this I need a layer to connect to the data. Unfortunately
> I ge the following error:
> (dutch for the external server returned an error)
> An exception occurred in FDO component.
> Unable to load the FDO Provider: (null)
> The errorlog tells me:
> <2009-09-18T10:40:23> 3508
> 127.0.0.1 Administrator
> Error: An exception occurred in FDO component.
> StackTrace:
> - MgFeatureServiceHandler.ProcessOperation line 83 file
> c:\osgeo\mapguide_21\mgdev\server\src\services\feature\FeatureServiceHandler.cpp
> - MgOpTestFeatureSourceConnection.Execute line 100 file
> c:\osgeo\mapguide_21\mgdev\server\src\services\feature\OpTestFeatureSourceConnection.cpp
> - MgFdoConnectionManager.Open line 262 file
> c:\osgeo\mapguide_21\mgdev\server\src\common\manager\FdoConnectionManager.cpp
> It looks like the problem lies within the libpq.dll file. Anybody a thought
> on how to solve this problem...
> Thanks in advance, Remco (The Netherlands)
> fdo-users mailing list
> http://lists.osgeo.org/mailman/listinfo/fdo-users
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
More information about the fdo-users
