AW: [fdo-users] FDO OGR-Driver 3.4.0 Connecting to PostGIS
8.2withAutoCAD Map 3d 2010 fails
Hermann Karl
Karl.Hermann at dornbirn.at
Tue Sep 29 10:50:59 EDT 2009
Dear Gwenael,
I tried to find out if the fdo ogr driver enables the use of the bulk copy function of autocad map 3d 2010
to import a esri-shape to postgis without the need to create the target table in postgis before.
The result is that it is not possible.
On the other hand i want to test the possibility of the utilization the complete functionality of the ogr/gdal library.
Best regards
Karl
-----Ursprüngliche Nachricht-----
Von: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] Im Auftrag von Gwenael Bachelot
Gesendet: Dienstag, 29. September 2009 16:31
An: FDO Users Mail List
Betreff: RE: [fdo-users] FDO OGR-Driver 3.4.0 Connecting to PostGIS 8.2withAutoCAD Map 3d 2010 fails
Hi Hermann,
Out of curiousity, why using FDO OGR instead of native FDO PostGIS ?
Cordialement,
Gwenael
Gwenael Bachelot - Mailto:gwenael.bachelot at autodesk.com
http://blogs.autodesk.com/geospatialfrance
-----Original Message-----
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Hermann Karl
Sent: mardi 29 septembre 2009 16:17
To: FDO Users Mail List
Subject: AW: [fdo-users] FDO OGR-Driver 3.4.0 Connecting to PostGIS 8.2 withAutoCAD Map 3d 2010 fails
Hi Frank,
Thanks for your reply.
If the gdal16.dll in the FDO/bin directory of AutoCAD Map 3d 2010 which is without PostgreSQL support is replaced with
\release-1500-gdal-1-6-mapserver-5-4\bin\GDAL16.DLL
\release-1500-gdal-1-6-mapserver-5-4\bin\GEOS_C.DLL
\release-1500-gdal-1-6-mapserver-5-4\bin\LIBCURL.DLL
\release-1500-gdal-1-6-mapserver-5-4\bin\LIBEXPAT.DLL
\release-1500-gdal-1-6-mapserver-5-4\bin\LIBPQ.DLL
\release-1500-gdal-1-6-mapserver-5-4\bin\SQLITE3.DLL
\release-1500-gdal-1-6-mapserver-5-4\bin\XERCES-C_2_8.DLL
from
http://vbkto.dyndns.org/sdk/
the OGR connect to PostGIS will work
http://geospatialfrance.typepad.com/geospatialfrance/2007/09/accs-natif-post.html
Best regards,
Karl
Von: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] Im Auftrag von Frank Warmerdam
Gesendet: Montag, 28. September 2009 18:43
Betreff: Re: [fdo-users] FDO OGR-Driver 3.4.0 Connecting to PostGIS 8.2 withAutoCAD Map 3d 2010 fails
Hermann Karl wrote:
> Dear List,
> trying to connect to PostGIS 8.2 from AutoCAD Map 3d 2010 with
> connectionstring
> PG:"dbname=databasename host=localhost port=5432 user=x password=y"
> following error message is launched
> OSGeo.FDO.Common.Execption: Connect failed:
> bei OSGeo.FDO.Connections.IConnectionImp.Open()
> bei
> Autodesk.Gis.Map.DataConnect.Plugins.GenericProviderConnectionPlugin.b
> uttonLogin_Click(Object
> sender, EventArgs e)
> in the readme of the FDO OGR-driver 3.4.0 there is following comment:
> So far the OGR provider has been (successfully) tested with:
> * SHP files
> * MapInfo files (.TAB)
> * Oracle Spatial
> * ESRI personal geodatabase (.mdb)
> * PostGIS (on PostgreSQL 8.1.4)
> the commandlinetools ogr2ogr or ogrinfo work with this connection
> syntax
Karl,
OGR is not built with postgresql support by default and I suspect the OGR driver you have lacks it. You can test the GDAL/OGR dll with depends.exe (if you have it) to see if it has a dependency on the libpq.dll (the postgres client library).
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
fdo-users mailing list
fdo-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users
