[fdo-users] RE: FDO 3.5 RC1 crashes MGOS v2.1
miansi
AndreiSinelnikov at SierraSystems.com
Tue Apr 13 17:37:58 EDT 2010
Aha!!! I knew I missed something J
Thank you!
[mailto:ml-node+4898577-875654693-175132 at n2.nabble.com]
Sent: Tuesday, April 13, 2010 3:26 PM
To: Sinelnikov, Andrei
Subject: RE: FDO 3.5 RC1 crashes MGOS v2.1
Hi Andrei,
You cannot use FDO 3.5 with MGOS v2.1; they are not compatible. You need
to use FDO 3.4 with MGOS v2.1. You can use FDO 3.5 with MGOS 2.2 when
it comes out (hopefully soon).
Tom
-----Original Message-----
<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=4898577&i=0>
[mailto:[hidden email]
<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=4898577&i=1> ]
On Behalf Of miansi
Sent: Tuesday, April 13, 2010 2:50 PM
To: [hidden email]
<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=4898577&i=2>
Subject: [fdo-users] FDO 3.5 RC1 crashes MGOS v2.1
Hello,
Just tested FDO 3.5 RC1 on MGOS v2.1.
Currently I am using FDO, which comes with MGOS v2.1 install and patched
for SQL Server from Autodesk to resolve feature selection problem in SQL
2008. I raised that defect long time ago but seems that it wasn't
resolved
in FDO v3.4, so I wanted to see if that was resolved in FDO v3.5.
1. I stopped MGOS service
2. I replaced all files in:
c:\Program Files (x86)\OSGeo\MapGuide\Server\Fdo
with files from FDO download section (32 bit)
3. Start MGOS Service
4. Restarted IIS
My test server is Windows Server 2008 R2 Standard x64.
I was able to connect to the server using Maestro. But as soon as I
tried to
see Dataconnection properties or create new Dataconnection MGOS Service
stops and I saw an error:
http://n2.nabble.com/file/n4898413/FDO_v3.5.png
I also tried x64 version of FDO v3.5, but I wasnt able to start MGOS
Service
at all with it.
Then I downloaded FDO v3.5 SDK and copied all files from bin directory.
After that I was able to see some errors in Error.log
In the error log file I see lots of references to
c:\osgeo\mapguide_21\mgdev
location. Is that a problem? As my MGOS installation located in
different
directory
Logs:
<2010-04-13T12:36:15> 2716
Success: Server started.
<2010-04-13T12:38:46> 2716
Success: Server stopped.
<2010-04-13T12:38:58> 4324
<2010-04-13T12:39:45> 4324
<2010-04-13T12:42:06> 4520
<2010-04-13T12:42:54> 4520
<2010-04-13T12:45:14> 4456
<2010-04-13T12:48:11> 1132
<2010-04-13T12:49:55> 4896
<2010-04-13T12:50:08> 3196 MapGuide Maestro v2.0.0.4650 ::1
Error: Session has expired or is invalid. Please log in again.
StackTrace:
- MgSiteServiceHandler.ProcessOperation() line 83 file
c:\osgeo\mapguide_21\mgdev\server\src\services\site\SiteServiceHandler.c
pp
- MgOpAuthenticate.Execute() line 107 file
c:\osgeo\mapguide_21\mgdev\server\src\services\site\OpAuthenticate.cpp
- MgServerSiteService.Authenticate() line 709 file
c:\osgeo\mapguide_21\mgdev\server\src\services\site\ServerSiteService.cp
p
- MgSecurityManager.Authenticate() line 224 file
c:\osgeo\mapguide_21\mgdev\server\src\common\manager\SecurityManager.cpp
- MgSessionCache.GetSessionInfo() line 175 file
c:\osgeo\mapguide_21\mgdev\server\src\common\manager\SessionCache.cpp
<2010-04-13T12:50:10> 2164 MapGuide Maestro API v2.0.0.4650 ::1
Administrator
Error: Resource was not found:
Session:123147be-295b-102d-8000-005056ad042e_en_0A22201F0AFC0AFB0AFA//79
334259-237b-41a2-9b3b-039984aa779b.FeatureSource
StackTrace:
- MgResourceServiceHandler.ProcessOperation() line 80 file
c:\osgeo\mapguide_21\mgdev\server\src\services\resource\ResourceServiceH
andler.cpp
- MgOpGetResourceContent.Execute() line 120 file
c:\osgeo\mapguide_21\mgdev\server\src\services\resource\OpGetResourceCon
tent.cpp
- MgServerResourceService.GetResourceContent() line 904 file
c:\osgeo\mapguide_21\mgdev\server\src\services\resource\ServerResourceSe
rvice.cpp
- MgApplicationRepositoryManager.GetResourceContent() line 383 file
c:\osgeo\mapguide_21\mgdev\server\src\services\resource\ApplicationRepos
itoryManager.cpp
- MgResourceDefinitionManager.GetResource
(MgSessionResourceContents.dbxml)() line 320 file
c:\osgeo\mapguide_21\mgdev\server\src\services\resource\ResourceDefiniti
onManager.cpp
- MgResourceContentManager.GetDocument() line 590 file
c:\osgeo\mapguide_21\mgdev\server\src\services\resource\ResourceContentM
anager.cpp
- MgResourceDefinitionManager.GetDocument
(MgSessionResourceContents.dbxml)() line 476 file
onManager.cpp
- MgResourceDefinitionManager.GetDocument() line 467 file
onManager.cpp
<2010-04-13T12:52:15> 4896
<2010-04-13T12:59:33> 4548
<2010-04-13T13:01:17> 4640 MapGuide Maestro v2.0.0.4650 10.34.36.97
Administrator
Error: An exception occurred in FDO component.
Unable to load the FDO Provider: The specified procedure could
not
be found.
StackTrace:
- MgFeatureServiceHandler.ProcessOperation() line 83 file
c:\osgeo\mapguide_21\mgdev\server\src\services\feature\FeatureServiceHan
dler.cpp
- MgOpTestFeatureSourceConnection.Execute() line 100 file
c:\osgeo\mapguide_21\mgdev\server\src\services\feature\OpTestFeatureSour
ceConnection.cpp
- MgFdoConnectionManager.Open() line 262 file
c:\osgeo\mapguide_21\mgdev\server\src\common\manager\FdoConnectionManage
r.cpp
<2010-04-13T13:01:41> 4548
<2010-04-13T13:02:43> 2668
Failed to load FDO library.
StackTrace:
- MgServer.open() line 1083 file
c:\osgeo\mapguide_21\mgdev\server\src\core\Server.cpp
- MgServer.svc() line 979 file
<2010-04-13T13:02:44> 2668
<2010-04-13T13:04:00> 4752
Did I miss something?
Thank you,
Andrei
View this message in context:
http://n2.nabble.com/FDO-3-5-RC1-crashes-MGOS-v2-1-tp4898413p4898413.htm
l
Sent from the FDO Users mailing list archive at Nabble.com.
fdo-users mailing list
[hidden email]
<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=4898577&i=3>
http://lists.osgeo.org/mailman/listinfo/fdo-users
[hidden email]
<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=4898577&i=4>
View message @
http://n2.nabble.com/FDO-3-5-RC1-crashes-MGOS-v2-1-tp4898413p4898577.htm
l
To unsubscribe from FDO 3.5 RC1 crashes MGOS v2.1, click here
< (link removed)
uaWtvdkBTaWVycmFTeXN0ZW1zLmNvbXw0ODk4NDEzfC0xMjAxODQ1NTcy> .
----Notice Regarding Confidentiality----
This email, including any and all attachments, (this "Email") is intended only for the party to whom it is addressed and may contain information that is confidential or privileged. Sierra Systems Group Inc. and its affiliates accept no responsibility for any loss or damage suffered by any person resulting from any unauthorized use of or reliance upon this Email. If you are not the intended recipient, you are hereby notified that any dissemination, copying or other use of this Email is prohibited. Please notify us of the error in communication by return email and destroy all copies of this Email. Thank you.
View this message in context: http://n2.nabble.com/FDO-3-5-RC1-crashes-MGOS-v2-1-tp4898413p4898632.html
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20100413/9ed9a622/attachment-0001.html
More information about the fdo-users
