[fdo-users] SQLite provider and transactions/batch inserts/
Badreddine Karoui badreddine.karoui at autodesk.com
Mon Apr 26 08:37:21 EDT 2010
Transaction is supported in 3.5:
http://svnmirror.osgeo.org/fdo/trunk/Providers/SQLite/Src/Provider/SltCapabilities.h
Badreddine
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Igor Jarm
Sent: Monday, April 26, 2010 7:56 AM
To: fdo-users at lists.osgeo.org
Subject: [fdo-users] SQLite provider and transactions/batch inserts/
Hello all!
I'm using SQLite FDO provider and need fast insert capabilities.
I had 4 options to test:
- individual inserts
(- transactions - not supported)
(- batch insert - not supported)
- compiled queries (*** see below)
I expected compiled queries would be comparable to SQLite transactions.
I'm, using code, that looks like this:
FdoPtr<FdoIInsert> ins = (FdoIInsert*)conn->CreateCommand(FdoCommandType_Insert);
while(!done)
    FdoPtr<FdoIFeatureReader> fr = ins->Execute();
    if(enoughExecutesToCommitToDatabase)  //100,1000,...
        ins = (FdoIInsert*)conn->CreateCommand(FdoCommandType_Insert);   //make a new one and release the old one
These are the results of timing 1000 inserts compared to unoptimized SQLite implementation:
- SQLite: 10.83s, 0.0108s per insert
- SQLite, transactions, 1000 per transaction: 0.19s, 0.0002s per insert
- FDO: 9.57s, 0.0096s per insert
- FDO: compiled queries, 1000 per commit, 9.49s, 0.0095s per insert
- FDO: compiled queries, 100 per commit, the same, etc. ...
Compiled queries are the same as executing individual inserts, .
Of course I could use SQLite directly but I have to keep everything in FDO.
Am I missing something?
Are there some plans to implement transactions or batch inserts for SQLite FDO provider?
Or is there some other way to speed up the inserts?
Thank you.
Igor Jarm
//Insert is special. We attempt to speed up inserts if the caller is cooperating.
//The contract is as follows -- as long as the caller reuses the SltInsert object,
//he is working with a compiled query and within a single transaction. Whenever
//the command object is freed, the transaction is committed.
class SltInsert : public SltCommand<FdoIInsert>
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20100426/6b6b3431/attachment.html
More information about the fdo-users mailing list
