[fdo-users] Re: SQLite provider and transactions/batch inserts/
Jackie Ng
jumpinjackie at gmail.com
Tue Apr 27 05:53:24 EDT 2010
Hi Igor,
I use the following bulk insert logic for FDO Toolbox. It is based on the
SQLiteConverter implementation, and has no adverse performance effects (that
I know of) for other providers:
Create the fdo insert command *ONCE*
Obtain a pointer/reference to its PropertyValues collection
For each feature to be inserted:
- Clear this collection
- Load up with property values to be inserted
- Execute the insert command
- Repeat
The key here is creating the insert command once, and reusing the property
value collection repeatedly.
Since you're working with C++ directly, you might as well look at the
SQLiteConverter source as it does what I just described.
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/SQLite-provider-and-transactions-batch-inserts-tp4962263p4967766.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users
