[fdo-users] AutoCAD Map 3d 2011 BulkCopy to PostGIS DB with
FDOPostgreSQL Provider 3.5
Hermann Karl
Karl.Hermann at dornbirn.at
Fri Apr 30 12:52:55 EDT 2010
Dear List,
### an Import of towns_poly.shp with shp2pgsql results in following
table
### when mapping the columns from the shapefile "towns.shp" to the
columns of the table "towns" in the postgis db bulkcopy will work
-- Table: towns
-- DROP TABLE towns;
CREATE TABLE towns
gid serial NOT NULL,
objectid bigint,
towns_id bigint,
town_id smallint,
town character varying(21),
fips_stco integer,
ccd_mcd character varying(3),
fips_place character varying(5),
pop1980 integer,
pop1990 integer,
pop2000 integer,
popch80_90 integer,
popch90_00 integer,
fourcolor smallint,
"type" character varying(2),
island smallint,
fips_mcd integer,
fips_count smallint,
shape_area numeric,
shape_len numeric,
the_geom geometry,
CONSTRAINT towns_pkey PRIMARY KEY (gid),
CONSTRAINT enforce_dims_the_geom CHECK (st_ndims(the_geom) = 2),
CONSTRAINT enforce_geotype_the_geom CHECK (geometrytype(the_geom) =
'POLYGON'::text OR the_geom IS NULL),
CONSTRAINT enforce_srid_the_geom CHECK (st_srid(the_geom) = 26986)
WITH (
OIDS=FALSE
ALTER TABLE towns OWNER TO postgres;
### bulkcopy of the shapefile "towns.shp" with FDOPostgreSQL Provider
3.5 to the public schema in postgis will result in the table
"towns_fdopoly" below
### the wrong srid 31254 in the create table statement is an srid of a
dataset which was already present in the schema public. The correct srid
of the prj file of "towns.shp" is 26986 (MA83)
### copying of the data in the columns shape_area and shape_len from
towns.shp to the postgis table which is already created from the
FDOPostgreSQLProvider as [numeric (19,11)]
### causes following error
### RDBMS: [PGRES_FATAL_ERROR] ERROR: Overflow by type >>numeric<<
### DETAIL: rounding a value of a column with precision 19, scale 11
has to have less then 10^8
-- Table: "TOWNS_FDOPOLY"
-- DROP TABLE "TOWNS_FDOPOLY";
CREATE TABLE "TOWNS_FDOPOLY"
"FeatId" serial NOT NULL,
"OBJECTID" numeric(10,0),
"TOWNS_ID" numeric(10,0),
"TOWN_ID" numeric(3,0),
"TOWN" character varying(21),
"FIPS_STCO" numeric(5,0),
"CCD_MCD" character varying(3),
"FIPS_PLACE" character varying(5),
"POP1980" numeric(6,0),
"POP1990" numeric(6,0),
"POP2000" numeric(6,0),
"POPCH80_90" numeric(5,0),
"POPCH90_00" numeric(5,0),
"FOURCOLOR" numeric(1,0),
"TYPE" character varying(2),
"ISLAND" numeric(1,0),
"FIPS_MCD" numeric(8,0),
"FIPS_COUNT" numeric(3,0),
"SHAPE_AREA" numeric(19,11),
"SHAPE_LEN" numeric(19,11),
"Geometry" geometry,
CONSTRAINT pk_public_towns_fdopoly PRIMARY KEY ("FeatId"),
CONSTRAINT "enforce_dims_Geometry" CHECK (st_ndims("Geometry") = 2),
CONSTRAINT "enforce_srid_Geometry" CHECK (st_srid("Geometry") = 31254)
WITH (
OIDS=FALSE
ALTER TABLE "TOWNS_FDOPOLY" OWNER TO postgres;
-- Index: towns_fdopoly_geometry_si
-- DROP INDEX towns_fdopoly_geometry_si;
CREATE INDEX towns_fdopoly_geometry_si
ON "TOWNS_FDOPOLY"
USING gist
("Geometry");
Karl
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20100430/6de71ee8/attachment.html
More information about the fdo-users
