[fdo-users] Re: Storing MultiCurvePolygon King Oracle Provider
Brad Nesom
kidsmake6 at msn.com
Tue Dec 7 23:26:17 EST 2010
I would think that Bryan Hall could help on the OTN spatial forum. Sorry to
direct to another list but...
http://forums.oracle.com/forums/forum.jspa?forumID=76
On Tue, Dec 7, 2010 at 9:05 PM, Zac Spitzer <zac.spitzer at gmail.com> wrote:
> are the GEOMS 2d or 3d? Simons example is 2d
> aside: the -180 -90 stuff is a bit quirky... folklore is that some of
> the oracle spatial guru's
> recommend always putting those default value in place, while many spatial
> apps
> assume those are the default extents.. but I think it might dates back
> to the older
> quad tree indexing(?) days
> z
> On Wed, Dec 8, 2010 at 1:15 PM, Brad Nesom <kidsmake6 at msn.com> wrote:
> > I am wondering if you poly is too large. I seem to remember some threads
> on
> > oracle spatial discussing trying to contain an entire globe dataset
> > incompassed by the 4326 wkid. I am way out of my element here but your
> -180,
> > -90 made me think of that.
> > Brad
> > On Tue, Dec 7, 2010 at 4:17 AM, Simon Pelicon <simon at sl-king.com> wrote:
> >> Hi!
> >> I have no problems saving MultiCurvePolygons into Oracle
> using AutoCadMap
> >> 2010 (or 2011).
> >> I am using KingOracle provider version 0.8.23.
> >> My SQL for the SDO_GEOM_METADATA_TABLE value is:
> >> INSERT INTO MDSYS.SDO_GEOM_METADATA_TABLE VALUES ('SIMON','VDITCH',
> >> 'GEOMETRY',MDSYS.SDO_DIM_ARRAY(MDSYS.SDO_DIM_ELEMENT('X',
> >> -180,180,0.005),MDSYS.SDO_DIM_ELEMENT('Y', -90,90, 0.005)),4326);
> >> simon
> >> On Mon, Dec 6, 2010 at 9:41 AM, GISkit_Paul <paul at giskit.nl> wrote:
> >>> Hello,
> >>> Although Simon’s suggestion seems logical, it doesn’t solve the
> problem.
> >>> Using the same Oracle table, AutoCadMap 2010 (or 2011), connecting via
> >>> the
> >>> standard Oracle Connection, I can add hand-drawn MultiCurvePolygons.
> >>> Using AutoCadMap 2010, connecting via the King Oracle provider and
> >>> manually
> >>> adding MultiCurvePolygons causes the same error. Is the problem perhaps
> >>> caused by the King Oracle Provider?
> >>> Regards,
> >>> Paul
> >>> View this message in context:
> http://osgeo-org.1803224.n2.nabble.com/Storing-MultiCurvePolygon-King-Oracle-Provider-tp5773817p5807022.html
> >>> Sent from the FDO Users mailing list archive at Nabble.com.
> >>> _______________________________________________
> >>> fdo-users mailing list
> >>> fdo-users at lists.osgeo.org
> >>> http://lists.osgeo.org/mailman/listinfo/fdo-users
> Zac Spitzer
> Solution Architect / Director
> Ennoble Consultancy Australia
> http://www.ennoble.com.au
> http://zacster.blogspot.com
> +61 405 847 168
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20101207/bdeea84a/attachment.html
More information about the fdo-users
