[fdo-users] Re: Autodesk FDO provider shows only first point from
multipoint geometry in Oracle!?
Jonio, Dennis (Aviation)
DJonio at miami-airport.com
Fri Dec 10 10:17:11 EST 2010
Well, to be frank and honest the SDO_GEOMETRY you provided does not come close to meeting the Oracle specification for a MILTIPOINT and IMHO should have not passed validation. I am sure it only passed because MULTIPOINT is a SUPERSET of POINT and your first elem_info triplet( 1,1,1) has the signature for a valid point. So Oracle says it’s a point and evidently so does Autodesk Oracle provider. They were generous with you. ;-)
Yes, within 10.2g _Oracle Spatial User’s Guide and Reference_ read Chapter 2 “Oracle Spatial Data Types and Metadata”.
Focus on _Values and Semantics in SDO_ELEM_INFO_ basically the triplet for a SDO_GTYPE: X005(MULTIPOINT) is sdo_etype = 1, sdo_interpretation = number of points.
Keep in mind that in many cases and at a certain level the SDO_ GYTPE is really nothing more than a _convenieince_ value. Whenever the ordinates and elem_info are _unpacked_ you will find that they will _overrule_(lack of better term) the SDO_GTYPE.
Yes, I know it is confusing but it is what it is …
r,
dennis
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of mighty_duck
Sent: Friday, December 10, 2010 8:20 AM
To: fdo-users at lists.osgeo.org
Subject: [fdo-users] Re: Autodesk FDO provider shows only first point from multipoint geometry in Oracle!?
Hi dennis,
yes it works now, thx. a lot :)..but Im little bit confused now with format, so may you explain me now meaning of
MDSYS.SDO_ELEM_INFO_ARRAY(1,1,3)
Example: I have 15 points will it be then only
MDSYS.SDO_ELEM_INFO_ARRAY(1,1,15)
or there is some other rule. Honestly I have never seen this format for multipoint in Oracle and my potential problem now is that all current data in oracle has old format and it seems I will need to switch it...
Thanks
Minja
On Fri, Dec 10, 2010 at 1:30 PM, djonio [via OSGeo.org] <[hidden email]> wrote:
Yes, yours validates but .... I believe this one is "technically
correct" ... give it a try ....
MDSYS.SDO_GEOMETRY(2005,4326,null,MDSYS.SDO_ELEM_INFO_ARRAY(1,1,3),MDSYS
.SDO_ORDINATE_ARRAY(18.5272949231966,43.9245558053237,18.527391754093,43
.924240327095,18.5310243924313,43.9252225514267))
r,
dennis
-----Original Message-----
From: [hidden email] <http://user/SendEmail.jtp?type=node&node=5822896&i=0>
[mailto:[hidden email] <http://user/SendEmail.jtp?type=node&node=5822896&i=1> ] On Behalf Of mighty_duck
Sent: Friday, December 10, 2010 5:47 AM
To: [hidden email] <http://user/SendEmail.jtp?type=node&node=5822896&i=2>
Subject: [fdo-users] Autodesk FDO provider shows only first point from
Hi all,
I have strange problem, and I really hope there is something stupid in
this
that Im not able to note :)
I have multipoint geometry in Oracle:
MDSYS.SDO_GEOMETRY(2005,4326,null,MDSYS.SDO_ELEM_INFO_ARRAY(1,1,1,3,1,1,
5,1,1),MDSYS.SDO_ORDINATE_ARRAY(18.5272949231966,43.9245558053237,18.527
391754093,43.924240327095,18.5310243924313,43.9252225514267))
I created layer in mapguide studio 2010 using autodesk fdo provider for
Oracle and it should show me three points on the map, but I can only see
the
first one :(.
Does anyone know what is the problem here, I hope this is not FDO bug,
otherwise I will need to find another approach.
Any remarks will be very important for me. If you know this issue as bug
please let me know about that.
NOTE: Im not able to switch to other FDO providers because my code
design is
fixed to autodesk fdo provider.
Thanks in advance
Minja
View this message in context:
http://osgeo-org.1803224.n2.nabble.com/Autodesk-FDO-provider-shows-only- <http://osgeo-org.1803224.n2.nabble.com/Autodesk-FDO-provider-shows-only-?by-user=t&by-user=t>
first-point-from-multipoint-geometry-in-Oracle-tp5822675p5822675.html
Sent from the FDO Users mailing list archive at Nabble.com.
fdo-users mailing list
[hidden email] <http://user/SendEmail.jtp?type=node&node=5822896&i=3>
http://lists.osgeo.org/mailman/listinfo/fdo-users
Email Scan by McAfee
[hidden email] <http://user/SendEmail.jtp?type=node&node=5822896&i=4>
View message @ http://osgeo-org.1803224.n2.nabble.com/Autodesk-FDO-provider-shows-only-first-point-from-multipoint-geometry-in-Oracle-tp5822675p5822896.html <http://osgeo-org.1803224.n2.nabble.com/Autodesk-FDO-provider-shows-only-first-point-from-multipoint-geometry-in-Oracle-tp5822675p5822896.html?by-user=t>
To unsubscribe from Autodesk FDO provider shows only first point from multipoint geometry in Oracle!?, click here <http://osgeo-org.1803224.n2.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5822675&code=bXNpbGplZ292aWNAZ21haWwuY29tfDU4MjI2NzV8MTAyMDg2MDkzNQ==&by-user=t> .
View this message in context: Re: Autodesk FDO provider shows only first point from multipoint geometry in Oracle!? <http://osgeo-org.1803224.n2.nabble.com/Autodesk-FDO-provider-shows-only-first-point-from-multipoint-geometry-in-Oracle-tp5822675p5823023.html>
Sent from the FDO Users mailing list archive <http://osgeo-org.1803224.n2.nabble.com/FDO-Users-f2048584.html> at Nabble.com.
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20101210/57a5039c/attachment.html
More information about the fdo-users
