[fdo-users] Thiessen Polygons in Autocad Map
Brad Nesom kidsmake6 at msn.com
Mon Feb 8 00:26:35 EST 2010
http://www.vugtk.cz/odis/sborniky/jine/geos06/paper/68_vasilev_nikolova/paper/68_vasilev_nikolova.pdf
Methods for interpolation of data in Autodesk Civil 3D
Autodesk Civil 3D supports two main interpolation methods: *the Natural
Neighbor Method *and
the Kriging Method
*civil 3d is built on top of autodesk map. however map does not have most of
the surface modeling that civil 3d does. (You can build contours from dems)
On Sun, Feb 7, 2010 at 7:32 PM, Martin Morrison <martin.morrison at edsi.com>wrote:
> Try asking here:
> http://discussion.autodesk.com/forums/forum.jspa?forumID=84
> ________________________________________
> From: fdo-users-bounces at lists.osgeo.org [fdo-users-bounces at lists.osgeo.org]
> On Behalf Of brujulas [gis at cadmax.es]
> Sent: Sunday, February 07, 2010 3:26 PM
> To: fdo-users at lists.osgeo.org
> Subject: [fdo-users] Thiessen Polygons in Autocad Map
> Hi!
> I am interested in making thiessen polygons with Autocad Map For a
> analysis,
> someone has done something similar??
> Thank you very much
> Greetings.
> http://n2.nabble.com/Thiessen-Polygons-in-Autocad-Map-tp4530889p4530889.html
> Sent from the FDO Users mailing list archive at Nabble.com.
> fdo-users mailing list
> http://lists.osgeo.org/mailman/listinfo/fdo-users
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20100207/a7a70d1a/attachment.html
More information about the fdo-users mailing list
