[fdo-users] Impossible to select an object on map mapguide
Haris Kurtagic
haris at sl-king.com
Tue Jan 12 06:13:10 EST 2010
Not sure what you mean by that but you can either use primary constrain on
view or you can use KingFdoClass metadata table to define column to use as
"Id" column in Fdo class.
Haris
On Tue, Jan 12, 2010 at 12:08 PM, Dejan Gregor <dejan.gregor at gmail.com>wrote:
> To conclude, it does not work 'real-time' Oracle Views.
> Thanks!
> Dejan
> __
> Dejan Gregor, MSc
> GISc Researcher and Consultant
> http://www.linkedin.com/in/dgregor
> http://n2.nabble.com/Impossible-to-select-an-object-on-map-mapguide-tp3806579p4290950.html
> Sent from the FDO Users mailing list archive at Nabble.com.
> fdo-users mailing list
> fdo-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-users
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20100112/a2e546af/attachment.html
More information about the fdo-users
