[fdo-users] Impossible to select an object on map mapguide
Haris Kurtagic
haris at sl-king.com
Tue Jan 12 09:22:11 EST 2010
Yes it is FDO_IDENTITY, you can use comma to separate fields if needed
Caching and using of FD schema in applications is something we could talk a
lot about in MG, Map and FDO :).
I have changed 3 times in provider in diff. versions if it cache FDO schema
or not.
Haris
On Tue, Jan 12, 2010 at 2:52 PM, Dejan Gregor <dejan.gregor at gmail.com>wrote:
> Haris,
> thanks for the information. I have deployed the SL King FDO metadata table
> along with the SL Kinf FDO provider for Oracle on MGE 2010 (it works fine).
> Which column of the SL Kinf FDO metadata table is actually defining in an
> Oracle View the primary key? I would like to set my 'FID' as a primary key
> in the FDO class.
> Is it maybe the FDO_IDENTITY?!
> With the Autodesk Oracle provider upon Oracle Views I have many issues that
> concern probably the PK identifier (highlight colour does not show, new
> added layers do not show up in MGE Studio, if not restarting the WWW and MG
> service, ...). I think there is a lot of caching behing MGE or the Autodesk
> FDO.
> Dejan
> Dejan Gregor, MSc
> GISc Researcher and Consultant
> http://www.linkedin.com/in/dgregor
> http://n2.nabble.com/Impossible-to-select-an-object-on-map-mapguide-tp3806579p4291646.html
> Sent from the FDO Users mailing list archive at Nabble.com.
> fdo-users mailing list
> fdo-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-users
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20100112/9a51cb2f/attachment.html
More information about the fdo-users
