[fdo-users] Impossible to select an object on map mapguide
Dejan Gregor
dejan.gregor at GMAIL.COM
Tue Jan 12 09:45:09 EST 2010
Haris, thank you for the information!
Orest, both criteria (pk and the user_sdo_geom_metadata) are valid. I
discovered that there is just a lot of 'unexpected' caching behind MGE
and/or Autodesk Oracle FDO that does not make a lot of sence. After
restarting services or the server, things work fine again ...
Dejan
Dejan Gregor, MSc
GISc Researcher and Consultant
http://www.linkedin.com/in/dgregor
View this message in context: http://n2.nabble.com/Impossible-to-select-an-object-on-map-mapguide-tp3806579p4291988.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users
