[fdo-users] RE: .net Wrapper quirks
Bohne thomas_bonsiepen at web.de
Sat Jul 24 06:02:57 EDT 2010
Hi Jacky,
thanks for your reply.
I  modified my code but still no luck. Even if I'm adding only one integer
value to my Insertcommand (without reading from source) i'm getting this
Exception ( less than before, but still there) ??
private void writeValues(FDO.IFDOSource source, FDO.IFDOSource target,
Graphics graphics)
            //Open Source Connection, if necessary
            if (source.Connection.ConnectionState !=
OSGeo.FDO.Connections.ConnectionState.ConnectionState_Open)
                source.Connection.Open();
            //Open Target Connection, if necessary
            if (target.Connection.ConnectionState !=
                target.Connection.Open();
            //Creating Select Command
            ISelect select =
source.Connection.CreateCommand(OSGeo.FDO.Commands.CommandType.CommandType_Select)
as ISelect;
            //setting featureClassName
            select.SetFeatureClassName(source.getFeatureClassName());
           //Filter source
            if (graphics.Filter.Length > 0)
                select.Filter =
OSGeo.FDO.Filter.Filter.Parse(graphics.Filter);
            //creating InsertCommand
            using (IInsert insert =
target.Connection.CreateCommand(OSGeo.FDO.Commands.CommandType.CommandType_Insert)
as IInsert)
            insert.SetFeatureClassName(target.getFeatureClassName());
           //Counter
            int counter = 0;
            //create Reader
            using (IFeatureReader sourceReader = select.Execute())
                while (sourceReader.ReadNext())
                    //Clear old insertcommand
                    insert.PropertyValues.Clear();
                    //Adding PropertyValues to InsertCommand
                    bool writeRecord = true;// fillRow( insert, source,
sourceReader, target.MyFeatureClass, graphics, counter);
                    insert.PropertyValues.Add(new PropertyValue("MOVEID",
new Int32Value(counter)));
                    if (writeRecord)
                        //Executing InsertCommand
                        using (IFeatureReader insertReader =
insert.Execute())
                            insertReader.Close();
                    counter++;
            source.Connection.Close();
            target.Connection.Close();
View this message in context: http://osgeo-org.1803224.n2.nabble.com/net-Wrapper-quirks-tp2049912p5332467.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users mailing list
