[fdo-users] RE: .net Wrapper quirks
Bohne
thomas_bonsiepen at web.de
Sat Jul 24 07:43:11 EDT 2010
Thank you too, Clayton Hotson.
Now I'm adding the Property value outside the loop, and only allocate the
value. I think that is what you meant?
Still no luck :-(
private void writeValues(FDO.IFDOSource source, FDO.IFDOSource target,
Graphics graphics)
//Open Source Connection, if necessary
if (source.Connection.ConnectionState !=
OSGeo.FDO.Connections.ConnectionState.ConnectionState_Open)
source.Connection.Open();
//Open Target Connection, if necessary
if (target.Connection.ConnectionState !=
target.Connection.Open();
//Creating Select Command
ISelect select =
source.Connection.CreateCommand(OSGeo.FDO.Commands.CommandType.CommandType_Select)
as ISelect;
//setting featureClassName
select.SetFeatureClassName(source.getFeatureClassName());
//Filter source
if (graphics.Filter.Length > 0)
select.Filter =
OSGeo.FDO.Filter.Filter.Parse(graphics.Filter);
//creating InsertCommand
IInsert insert =
target.Connection.CreateCommand(OSGeo.FDO.Commands.CommandType.CommandType_Insert)
as IInsert;
insert.SetFeatureClassName(target.getFeatureClassName());
PropertyValue moveIDValue = new PropertyValue();
moveIDValue.Name = new Identifier("MOVEID");
insert.PropertyValues.Add(moveIDValue);
//Counter
int counter = 0;
//create Reader
using (IFeatureReader sourceReader = select.Execute())
while (sourceReader.ReadNext())
//Clear old insertcommand
//insert.PropertyValues.Clear();
//Adding PropertyValues to InsertCommand
bool writeRecord = true;// fillRow(ref insert, source,
sourceReader, target.MyFeatureClass, graphics, counter);
//insert.PropertyValues.Add(new PropertyValue("MOVEID",
new Int32Value(counter)));
insert.PropertyValues[0].Value = new
Int32Value(counter);
if (writeRecord)
//Executing InsertCommand
using (IFeatureReader insertReader =
insert.Execute())
insertReader.Close();
//insert.Execute();
counter++;
insert.Dispose();
select.Dispose();
//source.Connection.Close();
//target.Connection.Close();
View this message in context: http://osgeo-org.1803224.n2.nabble.com/net-Wrapper-quirks-tp2049912p5332595.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users
