[fdo-users] Opening FDO 3.5 SQLite datastore with previous FDO
3.4
Igor Jarm
igor at sl-king.com
Tue Jul 27 17:56:20 EDT 2010
Hi Traian,
Thanks for your response.
I double checked everything and created a ticket #672 with a sample file and
code needed to reproduce the error.
Best regards,
Igor Jarm
On Tue, Jul 27, 2010 at 4:21 PM, Traian Stanev
<traian.stanev at autodesk.com>wrote:
> Hi Igor,
> Since the database format defined in RFC 16 hasn’t changed, a file created
> with 3.5 should work in 3.4 (as long as it was created with
> UseFdoMetadata=FALSE). If it does not, it’s probably a bug. You can create a
> ticket and attach a sample database?
> Traian
> *From:* fdo-users-bounces at lists.osgeo.org [mailto:
> fdo-users-bounces at lists.osgeo.org] *On Behalf Of *Igor Jarm
> *Sent:* Tuesday, July 27, 2010 9:22 AM
> *To:* fdo-users at lists.osgeo.org
> *Subject:* [fdo-users] Opening FDO 3.5 SQLite datastore with previous FDO
> 3.4
> Hello,
> I was under the impression that FDO 3.4 should be able to open FDO 3.5.
> datastores, but I have problems with that.
> Describe schema and select both throw exception:
> "(.\Src\Fdo\Schema\GeometricPropertyDefinition.cpp: 110) The provided
> input is invalid for the current mapping process."
> This file contains a geometric property of type FdoGeometricType_All but
> that's beside the point since this property has to stay.
> I tryed to set the new datastore/connection property UseFdoMetadata both to
> TRUE and to FALSE with the same exception:
> FdoPtr<FdoIDataStorePropertyDictionary> dictionary =
> pCreateCmd->GetDataStoreProperties();
> dictionary->SetProperty( L"UseFdoMetadata", L"TRUE" );//and L"FALSE"
> I also tryed opening this file in Map 2010 and while "Data connect" reports
> no error it also doesn't show any schema or class, so it doesn't work.
> Is there a way for FDO 3.4 SQLite provider to open FDO 3.5. SQLite file?
> Thanks in advance!
> Best regards,
> Igor Jarm
> fdo-users mailing list
> http://lists.osgeo.org/mailman/listinfo/fdo-users
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20100727/fc3e02e3/attachment.html
More information about the fdo-users
