[fdo-users] Problems with FDO: HasElevation is always false
Haris Kurtagic
haris at sl-king.com
Tue Jun 1 06:24:33 EDT 2010
Simon checked it and it is true that King.Oracle always set it to
false ( M as well).
I will fix it .
BTW, Apply schema in King.Oracle would correctly set SDO metadata in
case of elevation or measure.
Haris
On Mon, May 31, 2010 at 2:53 PM, hanko
<hana.jaborova at spatialtechnology.se> wrote:
> I'm using OSGeo.KingOracle.3.4 provider. I'm reading a FeatureSchema from
> Oracle db and for every FeatureClass I want to create a shape file.
> Problem is that HasElevation property of GeometricPropertyDefinition seems
> always false.
> private bool CheckElevation(IConnection conn, PropertyDefinition property,
> string featureClassName)
> GeometricPropertyDefinition dp = (GeometricPropertyDefinition)property;
> using (ISelect select =
> conn.CreateCommand(OSGeo.FDO.Commands.CommandType.CommandType_Select) as
> ISelect)
> select.SetFeatureClassName(featureClassName);
> string wktGeo = "";
> using (IFeatureReader reader = select.Execute())
> if (reader.ReadNext())
> byte[] geom = reader.GetGeometry(property.Name);
> using (FgfGeometryFactory gFac = new FgfGeometryFactory())
> using (IGeometry geo = gFac.CreateGeometryFromFgf(geom))
> wktGeo = geo.Text;
> reader.Close();
> // Check elevation
> int xyz = wktGeo.IndexOf("XYZ", StringComparison.OrdinalIgnoreCase);
> int xymz = wktGeo.IndexOf("XYMZ", StringComparison.OrdinalIgnoreCase);
> return (dp.HasElevation || xyz >= 0 || xymz >= 0);
> 1.
> Value of wktGeo in the debugger is:
> "LINESTRING (155278.193274153 6414488.75171899, 155276.3381056
> 6414487.64186301, ...
> HasElevation = false
> 2.
> "LINESTRING XYZ (161703.634666022 6410352.31957678 56.868, 161705.440817796
> 6410353.98074014 56.868, ...
> also HasElevation = false
> Second case causes exception when executing an IApplySchema command for
> creating shape files.
> Thanks for your time.
> Best regards,
> Hanko
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Problems-with-FDO-HasElevation-is-always-false-tp5121682p5121682.html
> Sent from the FDO Users mailing list archive at Nabble.com.
> fdo-users mailing list
> fdo-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users
