[fdo-users] Re: Number of geometry types in Oracle FeatureClass
hanko
hana.jaborova at spatialtechnology.se
Thu Jun 10 07:26:31 EDT 2010
A Good advice is worth gold
I have already tried use SQL statement command in FDO. I cannot get it work.
I would appreciate a working code example.
public void SQLQuery()
// create the command
ISQLCommand sqlCommand =
(ISQLCommand)FDOConnection.CreateCommand(OSGeo.FDO.Commands.CommandType.CommandType_SQLCommand);
int count = 0;
sql = "SELECT COUNT(1) AS CONT FROM MYTABLE t WHERE t.GEOMETRY.sdo_gtype
IN (2001,3001,2005,3005)";
//or
sql = "SELECT COUNT(1) AS CONT FROM KingOra:MYSCHEMA~MYTABLE~GEOMETRY t
WHERE t.GEOMETRY.sdo_gtype IN (2001,3001,2005,3005)";
sqlCommand.SQLStatement = sql;
try
count = sqlCommand.ExecuteNonQuery();
//ISQLDataReader dataReader = sqlCommand.ExecuteReader();
catch (OSGeo.FDO.Common.Exception ex)
System.Console.WriteLine(ex.Message +" " + ex.InnerException);
Exception: "ora-24374 define not done before fetch or execute and fetch"
Cheers
Hanko
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Number-of-geometry-types-in-Oracle-FeatureClass-tp5161882p5162697.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users
